Old 08-27-2009, 11:51 AM
Stunt Driver's Avatar
Stunt Driver Stunt Driver is offline
Stunt Driver is on a distinguished road
Default kWH monitoring system - anyone has build recipe?
I would like to keep track of energy use in car - kWH meter. Ideally - both charge and run.
All that is needed - proper microcontroller, that will multiply current by voltage and summ it up in small intervals - giving kWH number. Knowing battery pack capacity - this would be a perfect meter to tell how much is left.
Also, by measuring charging capacity - would be easy to tell efficiency of battery pack. I have a feeling that my old LA troyans take 3 times more charge than what they are able to give back later.
So is there an easy recipe to use?
Old 08-29-2009, 10:49 PM
neanderthal neanderthal is offline
neanderthal is on a distinguished road
Default Re: kWH monitoring system - anyone has build recipe?
I don't think there is an easy way to do this. I believe that some SOC meters actually measure this, but most just look at voltage and then estimate
I think that this one does it the "batman"
http://www.cloudelectric.com/product_p/me-bm-ev-200.htm
Old 08-31-2009, 09:20 AM
Nice unit indeed. Just a bit too exepnsinve for my project. Still many thanks for link - at least I know what exists.
SInce I have my volt and amp meters bought from ebay at very reasonable price - AH meter is the only part on wish-list. Will be looking for ways to assemble it
Just doesn't seem right: KillaWatt is $35 for all the same features. So DC meter doesn't have to cost $500 by nature of it.
Old 09-02-2009, 10:59 PM
Lordwacky Lordwacky is offline
Lordwacky is on a distinguished road
an easy way to record the power you input into the car (including charging loses) is to buy a standard home electrical meter off ebay and wire it inbetween the outlet and charger. It will measure the kW-hr used during each charge cycle. You then divide by the miles traveled between each charge cycle to get a kW.hr/mile figure.
the best way to record energy output of the car is to do what you propose, gather the Battery voltage*current and time intervals and integrate over time. There are BMS systems out there that do this, I think the paktrakr can do it.
Old 09-03-2009, 11:49 AM
So using KillA Watt at charging is easy, and gives some interesting info. Only costs $25,
But those BMS that you point to - cost well over $500, which is unreasonably expensive.
I am looking to have a simple kWH reading while driving. There must be microcontrollers that are able to do that, but i'm not familiar with that world. I bet total cost of such device could be $20 plus display
Old 09-03-2009, 12:41 PM
I am looking to have a simple AH reading while driving. There must be microcontrollers that are able to do that, but i'm not familiar with that world. I bet total cost of such device could be $20 plus display
Yes using a Killawatt is easy as long as you are charging at 110V and low current (15amps or lower). There have been cases where Killawatts have blown under the heavy use associated with an EV.
essentialy all the paktrakr is is a micro controller that does what you want with added BMS features, but it is a bit spendy.
Curtis has some SOC meters that might work for you. They tend to be for lower voltages though. I'm not sure what price you are willing to pay, nor do I know the voltage of your conversion. But you can see if any of these will work for you.
http://curtisinst.com/index.cfm?fuse...istDS&CatID=25
Old 09-03-2009, 01:47 PM
Thanks, interesting!
But SOC is really a volt meter, and as I see - doesn't monitor amount of electricity passed thru it. Am I looking for something too weired?
Old 09-05-2009, 02:24 AM
parscheese parscheese is offline
parscheese is on a distinguished road
http://www.ebikes.ca/drainbrain.shtml
Old 09-05-2009, 02:53 AM
AmpEater AmpEater is offline
AmpEater is on a distinguished road
Originally Posted by parscheese View Post
I think the cycle analyst is exactly what you want, not very expensive either.
If that is too much it wouldn't be super hard to roll your own.
Something like an arduino or other cheap microcontroller, doing instantaneous voltage combined with a shunt and some basic math (maybe record average current over 10 second intervals?) should get you a reasonably accurate kwh reading.
Compare with kill-a-watt and you'd have an excellent idea of kwh left, plus overall efficiency of your batteries.
Old 09-05-2009, 04:32 AM
Amberwolf's Avatar
I agree that the CA is the most informative option for the price--it's what I was going to suggest when I saw the thread title, but I was beaten to it.
There are others around that do similar things, but they are not nearly as capable as the CA. I'd have one on my ebike if I had the money for it right now. (I still will if I can ever get out of this hole).
Watch me build an electric bike from assorted junk!
Alternative Energy Sources for the Home from Recycled Junk
ReThink, RePurpose, ReUse.™
A subsidiary of Cybernetic Necromancers, Discorporated:
"We Bring Dead Things To Life"
