Originally Posted by Colonel Monk
We're buying capacity, right?
capacity balanced with life, available space and weight...
4 - G27 Trojan scs200 12V @ 115 Ah = 4(12*115) = 5520 Wh
$189.95 EA so bank will cost $759.80 - .14 cents per Wh
4 - GC2 Trojan T-105 6V @225 Ah = 4(6*225) = 5400 Wh
$149.95 EA so bank will cost $599.80 - .11 cents per Wh
.... but you 'probably' need twice as many 6v for a specific system. 4x12v are not gonna be enough for an EV in any case. In the case of the RV, you probably have an inverter that is hard-wired for 48v, and an EV needs at least 96v to be highway capable. You really shouldn't split the pack and use half for other purposes while the other half sits around..... You could put half the pack in parallel, and have a MASSIVE 48v system for your RV.
Is there a lower cost / same quality alternative to Trojan?
Is there a 6V deep cycle batt with similar capacity that is shorter than GC2?
sometimes you can find Interstate batteries which are re-labelled USBatteries which are very good too. Problem that most of the deep cycles are taller than typical 'marine' batteries that RVs are built for.
