Old 06-19-2012, 11:39 PM
John Metric's Avatar
John Metric John Metric is offline
John Metric is on a distinguished road
Default Lenco now offering overdrive unit.
I have talked with Gary Sumek at Lenco Racing over several weeks.
They can now offer a permanent overdrive to the back end of a Lenco CS2 racing system. The unit runs about $2600.
It comes between 1:1.56 and 1:1.31 overdrive.
The 1:1.56 overdrive is a 0.64 ratio this would really help a landspeed racer or high speed drag racer at the top end.
Call me if you have any questions, I have already asked him a lot of them.
It is a non-standard part and he will try to sell you a transwarp motor adapter plate and a full system as well. It is basically the reverse of the underdrive "gear reducer" they sell.
http://www.lencoracing.com/LENCODriv...asterPage.html
He would only put it on the back of a Lenco CS2 without paying for full development costs. So it is a little bit of a big gulp to take. But if you are into building custom plates and shafts this could be for you.
John Metric
979-665-5621
Metric ampahaulic.com
DCP 9s-1/4mi 155mph-1mi
A&B 5s-1/8mi
LoneStar EV Racing
DIY DCP A&B
Old 06-21-2012, 05:16 PM
DanGT86 DanGT86 is offline
DanGT86 is on a distinguished road
Default Re: Lenco now offering overdrive unit.
So they consider it standard when its on the back of their CS2 transmission and it costs $2600? Putting it directly on a transwarp (like DC plasma's Gearvendor) is what costs extra?
By permanent do you mean it is not switchable? I guess what I mean is can it be used to make a 2 reduction lenco into a 2 reduction+2od=4speed?
Tried to make that not confusing. Hope it worked.
Old 06-24-2012, 01:18 AM
$2600, Yes, pricey, eh? Building the TWarp adapter costs $450 extra.
Permanent, meaning it's always active, no switching it on or off like GV.
My solution to this problem is in my Assualt&Battery build thread. Two cases, four speeds. plus reverse and neutral. Used parts about $3200.
A&B 5s-1/8mi
LoneStar EV Racing
DIY DCP A&B
Old 06-25-2012, 11:52 AM
GerhardRP GerhardRP is offline
GerhardRP is on a distinguished road
Does that mean it will transmit torque in both directions and both speeds? Thinking Regenerative Braking.
Gerhard
Edit: I misunderstood. This is a fixed gear, not a shiftable overdrive, so I wonder what advantage it has.
G.
overdrive transmission
