Li-tec batteries from 2013 smart car
21K views 35 replies 8 participants last post by  jimmyaz
#1 ·
Is anyone using salvage smart car cells from Li-tec? I just got some on ebay and will be learning about them...
I found this test that seems to show min/max cell voltages of 3 and 4.2:
http://energy.gov/sites/prod/files/2015/02/f19/batterySmart5544.pdf
It looks like the low-voltage knee is at 310v or 3.333 volts per cell.
and their graph starts at about 385v or 4.14 volts per cell.
Any more/better/different information out there?
#2 ·
Hello, I have also acquired some Smart Fortwo Li-Tec battery modules.
I've done a bit of searching and I hope that the information that I found is helpful or even useful to this conversation as I am still trying to ascertain what charger and what kind of charge parameters I will need myself.
I searched primarily for Li-Tec related information, some of the links look like they were multimedia presentations for whatever purposes. (The engineers talking to the pointy haired boss perhaps?)
I hope that these links will be useful as many of them are simply touting the technology in the batteries. However there are nuggets of (seemingly) useful information in all the links that I am providing.
In no particular order:
http://www.trolleymotion.eu/www/uploads/tx_sbdownloader/Herr_Hennige__Vortrag_.pdf
http://corporate.evonik.de/sites/dc...ortrait/Portraet_Lithium-Ionen_-_englisch.pdf
https://www.drive-e.org/wp-content/uploads/vortraege_2010/3_Di_Zschech_LiTec_CERIO.pdf
http://s1b677a343c55ff35.jimcontent...i-ionbatteries Davos 21012011 proceedings.pdf
http://www.maynards.com/media/components/ams/events/AAKRR101315/LiTec-Expose_compressed.pdf
http://ma.ecsdl.org/content/MA2010-03/1/699.full.pdf
http://litarion.com/content/pdf/Brochure_LITACELL-Lithium-Ion-Cell.pdf
http://www.evs24.org/wevajournal/php/download.php?f=vol3/WEVJ3-1130258.pdf
http://www.tec.ch.tum.de/uploads/me...ures_-_Battery__Michele_P._for_Hubert_G._.pdf
#4 ·
It is my hope to wire my modules in parallel to create a 114v 150 ah battery pack.
From the information that the seller provided, it seems as though 125 amps continuous(per module) may be acceptable. Some information that I got from another eBay seller who briefly had some of these packs leads me to believe that 170 amps would also be acceptable from each module.
If true, then I am hoping that 375 amps continuous in parallel will work as well as at least 500 amps peak.
If the 40 ah cell is similar enough to the 52 ah cell, perhaps that 10c Max discharge statement would also apply. My application currently only requires 400 amps peak and my future plans only bump up to around 550 amps.
When possible I prefer to make conservative plans while simultaneously hedging on the side of overkill when applicable.
#7 ·
I have no idea how to make that work. Does removing the bms reveal how to tap the cells to apply a bms of your own or could you partially remove the bms and reuse those attachment points?
I still haven't unwrapped my three and poked around in the original case yet.
I feel as though I should purchase some minimum level of PPE when attempting to disconnect the series connections, but I am uncertain what I should do. I've seen some electrical PPE on eBay, they look like rubber gloves inside leather gloves. Am I overthinking this?
What type of fastener holds down the (what looks like laminated copper strips with light blue insulation) that they use to connect the batteries? (I'm assuming a metric fastener, but like Hex or Star or?)
#8 ·
i think there are three or four sizes of the six-pointed star nuts in there...
each cell's bms connection was a pinpoint solder or weld onto an exposed plate... no screw holes or tabs or anything. I didn't see a great way to attach my own wire onto there.
If I recall correctly, the contactors in the pack were rated for 250A and the fuse was a 225A so I would definitely not go over that (per block)... the ebay ad I got them from said 100A continuous and 125 peak I think.. it was from greentecautohybridspecialist in connecticut.
#9 · (Edited)
I don't know what a PPE is but I just took out the two flatbars between the blocks first and put tape over the contact points before i did anything else. Only touch one thing at a time. The flatbars are a totally straight shot so no awkward wrenching.
Also when you poke a knife or scraper or whatever into the gap to separate the halves of the case, make sure you don't poke it in very far, not much more than the depth of the flange. .. whoever opened mine poked into one of the contactors.
#10 ·
PPE= personal protective equipment (I was an EMT/Hazmat tech for a time.)
Basically it just means I wonder if I should insulate myself from the tools that I use or will using only one hand do the same trick?
I would be interested to see a writeup of how you took apart your batteries (with pictures) if that were possible? As well as your build up with adding in the 4th battery.
I am still uncertain how I want to integrate my batteries into my build.
#11 ·
When working with batteries it is wise to cover your tools, not because it insulates you from shock but from plasma balls if the tool touches both a positive and negative terminal. Trust us when we say a plasma ball is very dangerous. It will blow off hot molten metal and burns and ruins batteries and tools. Instantly.
#16 · (Edited)
What I don't quite understand, is how they attached the cable to the cells.
They seem to have fix/weld at different points the wire on the cell terminal and add silicone.
Good to pull a lot of Amps (relatively!!).
#21 ·
I have a couple photos of the cells mounted at evalbum.com/5187. I ended up using a third of the original bottom tray to set one block under the front seat, and welding a custom tray for the three blocks in the middle of the van.. then I will trim the original top cover to make an opening hatch cover for those blocks. I will make a separate cover for the front one too.
When I got the cells the blocks were around 112v i think. a while back they were down to 108 or 109 so I charged them at about 10A back to about 115v. so not much news electrically.
ebay seller ev-hv-battery seems to have half-blocks for sale now with or without BMS... here is the specs they list for a 14-cell unit with BMS:
Specifications:
Average voltage: 3.6V per cell, 14 cells in series - 50.4V average
Capacity - Rated 52Ah, Measured 53Ah -
Minimum voltage: 42V
Maximum voltage: 58.8V
Size 8" (9.5" with the side brackets) x 14" x 7"
Total weight: approx. 55lb
Installed BMS for balancing and overcharge protection
To connect to the golf cart you need a Andersen connector 175A red with 2AWG wires - we can add that for $35.
Chargers available - $168 for a 10A charger
#22 ·
further reading about running parallel strings:
http://elithion.com/pdf/BPC2012Elithion.pdf
makes me think I should break up the four blocks and make bricks of 4 cells in parallel and wire those in series.... I already mounted the 31 cell blocks though. dang. Also the tubes for the coolant are set up so nice for the blocks already. So I am considering going with a higher voltage drivetrain and using the three blocks in series, like in the original smart car, and maybe eventually getting two more blocks to have a second pack to use on long trips.
#29 ·
they are doing well but i am using them very lightly... i am starting to feel like i am not the best at building electric cars... i charge them up to 124v and use them down til about 113 and i guess that is 20 miles or so so it seems like the voltage drops too fast.... not sure if it hits a plateau somewhere maybe around 113, that would be nice, i was hoping for a range of about 60 for a 20kwh pack but im not ready to push it... i also always check if yall are selling more of these because i could easily stick another 3 pack in there for longer trips...
