Aloha, all. I am changing the bolts that came with my Calb 180's to 35mm ss studs (with allen female on top). Thinking is that I can use the whole alum or copper female connectors on the cell to the whole depth. Also I want to torque the busbar connectors ONCE and not have to ever remove them. The extra stud still showing above the buss bar will be for different monitoring things, BMS, and other connectors without needing to remove the bussbar.
Anyway what is the conclusion about using loctite to secure the studs and if using loctite or "threadlock" what strength to use?
thanks
Francis
thanks
Francis
