Old 11-17-2011, 06:51 AM
riwe riwe is offline
riwe is on a distinguished road
Default Luigi goes electric. Fiat 500 R + Agni 95-R
Hi all,
Just wanted to share my latest project. I'm converting a 1973 fiat 500 R to electricity. I've created a blog that could help other do the same.
Please see luigi500.blogspot.com for more information.
Best regards
Rikard
Old 11-17-2011, 07:44 AM
Salty9 Salty9 is offline
Default Re: Luigi goes electric. Fiat 500 R + Agni 95-R
Nice blog. Looks like it's going to be a fun build.
Old 11-17-2011, 08:02 AM
Jozzer's Avatar
Jozzer Jozzer is offline
Very nice, great combination of drive and car, I've been looking for a cheap Fiat 127 to pop an Agni into myself. The 127 is the smallest car you can actually fit a double bass into
What size battery pack do you think you'll be able to squeeze in?
Steve
Originally Posted by riwe View Post
Hi all,
Best regards
Rikard
*Mazda MX-5, Soliton 1, 300v 11" Kostov, 21KW/h Turnigy Lipo. 1050KG.
*Hudson Kindred Spirit 3 wheeler, twin Agni motors (70KW), 5KW/H pack. 300KG.
* +Lots of electric motorcycles!
www.jozztek.com
Old 11-17-2011, 12:47 PM
Yabert's Avatar
Yabert Yabert is offline
Hi
I'm also interested to know more detail about the battery pack you think use and where you will fit it.
My Smart Fortwo high power!
Old 11-17-2011, 02:07 PM
Originally Posted by Yabert View Post
Hi
Hi guys,
My plan is to use 26 Lifepo4 150Ah packs. They would be located in the front and in the back. But as you know that involves alot of $ so I guess I will start of with lead acid 50Ah just to get everything up and running.
Best regards
Rikard
Old 11-18-2011, 06:31 AM
Yabert's Avatar
From the graph I have find, a 50Ah lead battery will be rated at 20Ah when you discharge it at 2C (100A). 100A x 72v is just around 8hp!
So, because the 50Ah battery will cost 600-900$ (100$-150$ each) and because you can only use around 15-20 Ah of those cells, if it' just to do some test, you can maybe keep an eye on small LifePo4 cells.
For example, 26 cells 38120s 10Ah will cost around 400-500$ and 26 cells 40160s 16 Ah will cost around 700-800$.
Maybe this 20Ah: http://www.ev-power.eu/?p=p_46&sName...o4-cells-(3.2v)
I used 7 Kg of headway 10 Ah in my Smart fortwo to do some test. That worked great.... for short travels at low speed!
It's just an idea!
Old 11-18-2011, 11:15 AM
Hi yabert!
You got a good point. Testing with low amp lifepo4 also gives me a chance to learn more about bms and charging. Ideal would be to be able to use the cells from test in parallel wither real pack, but i guess the discharge C would be a problem.
What about pouch cells? Those are minimal in size and weight, what is the draw backs?
What are your recommendations regarding bms? It would be nice to have a bms and a charger that can communicate.
Best regards
Rikard
Old 11-21-2011, 05:26 AM
Yabert's Avatar
Nothing except the more complex multiple connection. But don't mix batteries chemistry.
I use Mini BMS: http://minibms.mybigcommerce.com/
Simple, low cost, communicate with charger.
etc...
I also use her EV display.
Old 11-21-2011, 05:32 PM
dtbaker's Avatar
dtbaker dtbaker is offline
cost....
bang for buck, and reliable delivery from a US warehouse, ease of wiring into a pack, I'd say CALBs are the current winner.
Dan
Old 11-21-2011, 06:23 PM
rwaudio's Avatar
rwaudio rwaudio is offline
I'm testing with a small pack of 20ah A123 pouches, 100lbs of battery gives me about 30km and good power and a top speed over 120km/h. I've also tested with 50lbs of battery and I get less range and speed, but works very well.
These cells are great because even a 60ah pack lets me draw 1000A without destroying anything.
How far and how fast would you get with 50-100lbs of lead?
Electric Porsche 944HV
http://electricporsche.ca
72 volt, agni, fiat 500, kelly
