Originally Posted by joamanya89
Hi, I will answer you on a longer mail in a few hours, but i'll need you to explain me a bit more (kind of translate) of a few things you have said before so I will be able to answer you more presisely, what means or what is "6 igbts" and "snubbers".
Sorry but is the lenguaje problem...
No problem. The IGBTs are "Insulated Gate Bipolar Transistors" which act as switches in the power stage. Generally you use six of them for a 3 phase inverter.
A snubber circuit is a circuit to minimize voltage spikes during switching events. Inductors (which is what your motor is) resist changes in current, and this resistance is manifest as voltage spikes. Snubbers use capacitors or diodes to limit these transient spikes.
