Originally Posted by blackpanther-st
Tesseract,
I seem to remember and old trick of placing a small value capacitor across the contacts of a DC switch to reduce the arcing. I think the idea was for the capacitor to hold the voltage differential just long enough for the contacts to fully separate. Are you familiar with this? Does it work?
Oh sure, but one usually uses an RC - aka. a snubber. After all, it doesn't matter whether the switch is mechanical or a MOSFET, when you switch an inductive load you must deal with the kickback produced when the switch opens. You could also use a Transzorb (ruggedized zener diode) or a MOV.
BUT, you have know the total circuit inductance, resistance and whether these ever change (ie - whether the load is fixed and known, or variable/unknown) to be able to select the right values for both the resistor and capacitor, while the transzorb or mov has to handle a peak current at least as high as the load current, and a peak energy that depends, once again, on the inductance.
So, there is not a universal snubber, and remember that both MOVs and Transzorbs tend to fail shorted.
