If one can use a centralized version of BMS like MiniBms where wire from every cell is coming to BMS and HVC, LVC etc are being controlled by circuit, why not make one where a microprocessor controls everything. In my opinion it will be easier and use less components. For too many number of cells it may be cumbersome to have so many of wire but for small packs like 16 or 24 cells, it will be easier. Signal from each cell will be directly fed to microprocessor (through a multiplexer) everything will be calculated inside the micpro and signal can be sent to charger and load.
As for the temperature of cell one can install thermistors at several locations and read it through multiplexer. Many times cells are in parallel as well as in series so cell boards are not on all cell top but on one cell in each series cell. In that case we are not getting temperature of each cell, by using thermistors we can ger temperature at any number of places and have better control and look of temperature.
What I want to convey is shown in attached image.
http://www.flickr.com/photos/mnikhilesh/8782209540/
I am a mechanical engineer so kindly forgive me if there is any feasibility issue from electronics point of view. I am just curious to know if its possible to have such a system as it will be a simple BMS solution for small battery packs.
