Old 11-24-2009, 11:02 AM
dimitri's Avatar
dimitri dimitri is offline
Default MiniBMS - open source project
All,
as I have been toying with the idea of simple and cheap BMS I realize that it would be best to make it an open source project. I'm pretty good at reading schematics and making electronics, but certainly not as smart and/or experienced as some folks on this board. I'd like this to be super technical thread with input from anyone who can contribute specific details, we can keep general discussion at the other threads.
I have researched various BMS types and designs for many months, I have contributed a little to Brian's Volt Blochers project, I made my own version of VBs, which is currently installed in my EV and works great, I have a couple of satisfied customers using my modules as well. Since VBs aren't available anymore and there seems to be a market for cheap, simple and reliable BMS ( see poll results in the New BMS poll thread ), I figured why not take the best ideas and try to implement it all in one universal product.
I especially liked the idea of simple BMS proposed by Johnny on Australian forum, so I have taken his schematic and applied few changes based on input from other BMS discussions. I also done some research on key components and their prices at Digikey, to make sure we keep total parts cost around $5 per cell.
In past few days I prototyped this schematic on a bread board using basic Radio Shack parts and it appears to work great. I really like how comparators allow precise and fast switching when voltage gets to trigger levels. It switched from on to off with 0.01V precision and very little hysteresis.
I'd like some input from pros out there, my goal is to minimize number of parts, improve anything that may need improvement, pick best resistor values and minimize different values so there is less different resistors to buy. For example, I think we can collapse R6 and R7 if we find LED with similar voltage drop as in optorelay, so they can share same current.
I'd like to use Clare CPC1014 optorelay for NC signal loop, since its the only suitable low on-resistance relay I found which can be purchased for 80 cents in reasonable quantity.
http://www.clare.com/home/pdfs.nsf/w...C1014N_R01.pdf
Using 4 comparators may seem complicated at first, but they are all integrated in one IC chip which only costs 22 cents in quantities
I'd like to use these trimpots, which can be bought for 85 cents, yet very reliable for automotive environment.
Since there are so many needs for various HLVC levels, I think trimpots are pretty much a necessity, and they reduce number of resistors a little.
http://www.bourns.com/data/global/PDFs/3361.pdf
Later in this thread I will post initial schemaitic for head end controller, where I will also need some input from the pros.
According to the poll, many people still want shunting function in their BMS, despite recent ideas against top balancing. I'd like to keep this as an option on the PCB and simply skip these components if one doesn't want them. I'd like to keep shunting current low, like 0.5A, to avoid heat sink on the transistor and use 5 Watt resistor, which is reasonably small to fit on PCB.
I will be designing a modular PCB for this, which will allow a number of modules on one PCB, yet be able to cut it in pieces if one wants per cell installation. This will reduce PCB cost and assembly labor. However, for this and other reasons I abandon an idea of PCB under terminal bolt, so I will just have holes for either wires or rigid bars as in my current BMS modules.
I am planning on SMD components to minimize PCB size and further reduce costs.
Once we have working design I can produce them for DIY community at best price possible. This will probably take some time, so if someone needs BMS today, you might want to explore other options.
So, please, look at the schematic and question every component, every connection, everything...
MiniBMS
E-Protege5 in the Garage
www.cleanpowerauto.com
Old 11-24-2009, 11:51 AM
dimitri's Avatar
Default Re: MiniBMS - open source project
I think I found the answer for relay capabilities at low output voltage.
This is from Clare datasheet.
Seems that it can pass 200 mA at 0.12V , which would happen if 100 units in series are driving 12V head end controller.
Did I get it right?
MiniBMS
Old 11-24-2009, 12:46 PM
Tesseract's Avatar
Tesseract is on a distinguished road
A few quick observations for now:
* restrict the range over which the LVC and HVC can be adjustable with additional resistors. We know about where each should be so make the adjustment window maybe 0.4V or so.
* Bypass the pot wipers to both + and - so they are always at AC ground - important to prevent switching ripple from the controller tripping the circuit.
* Add hysteresis (small amount of positive feedback) to the comparators so they don't oscillate. Oscillating comparators are really annoying.
* it might be more costly in parts, but much cheaper in labor, to use multiple SMT transistors in parallel with thermal vias to a copper heatsink/ground plane. Try to avoid going 4-layer if at all possible.
I did not really look at the circuit, just giving a few quick suggestions before jetting off to the anodizing shop to find out if we will once again be able to offer colors.
Jeffrey Jenkins
http://www.evnetics.com/
Old 11-24-2009, 09:17 PM
Dave Koller's Avatar
Dave Koller Dave Koller is offline
Dave Koller is on a distinguished road
All great comments - I will put in my schematic that has built in time delays for low and high and pulses the normal on led in the opto.. But Dimitri has a simple circuit... I just put in the delay and pulses so there was a delay under load times to prevent false open of the NC and which way things were going ..
Dave
Use URL below to see some of my build..
http://www.diyelectriccar.com/forums...urn-30356.html
Old 11-24-2009, 09:35 PM
Russco Russco is offline
Russco is on a distinguished road
Thumbs up Re: MiniBMS - open source project
Originally Posted by dimitri View Post
All,
Attachment 4947
I have done considerable work on a lithium LV HV shunting BMS.
I feel using 1960 comparators with a series zener reference can be accomplished much more precisely with the common 431 precision IC. Two 431's would provide LV and HV monitoring. If the HV monitor is set higher than the shunting voltage, such at 4.2 volts and 3.70 volts, a third 431 would be required for the shunting monitor. The five ohm shunt resistor is a little high, only providing about 0.8 amps. Usually a 1-2 ohm shunt at 10 watts are used with the larger AH cells.
User adjustable pots are questionable. Can the user connect his pot across one or two cells for a reference voltage and make the pot adjustments? Many users can't. SMT eliminates easy bias resistor changes by the user or you to recalibrate users BMS units.
I have found in testing that each NPN opto output has a drop of around .15 volts. Fifty cells would work fine from the 12 volt accessory battery, but 100 cells won't.
Good work Dimitri, keep it up. You're a real go-getter.
Russ from Russco Charger. Currently testing 600 amp IGBT modular controller priced well below $1K.
Old 11-24-2009, 10:00 PM
See my above schematic (uses 431's) - Dimitri plans on setting up the pots for all the various conditions - I think a person needs a reference supply to set them so that is something to think about on a DIY board. but a simple multi-meter may work.. He will be using FET optos - no drop to speak of.
BUT I will let him comment on that..
Dave
Old 11-25-2009, 06:35 AM
Tesseract's Avatar
Soooo.... you see some merit in using the 1970's era TL431 over the 1960's era '339, huh?
I really can't see how using 3 separate TL431's is any better than a single bandgap reference feeding voltage dividers/comparators. Especially since it's easy to give comparators hysteresis so the switching action can be snappy, rather than fuzzy (the TL431? not so much).
I definitely agree with this, though. If you are going to top balance 160Ah cells then you need to be able to shunt up to 2A. Whether you SHOULD top balance seems to be a matter of considerable debate, but that's for another thread...
Yep... I hate trim pots, but it still might be good/necessary to have a limited adjustment range... Dunno. I'm also concerned about the temperature coefficient of the cell voltage.
Maybe, but I can tell you for certain that unless these boards are totally SMT technology and machine-assembled it simply won't be worth anyone's while to sell them at the price DIY'ers, etc., are willing to pay. I mean, you can maybe charge $20 per cell of which you'll have a good $7-$9 in parts and pc board cost. If it takes more than 10 minutes to assemble, test and calibrate each one then it's simply not profitable. If your labor cost is $10 per hour or less, and still fast and accurate, then sticking with PTH technology might still be okay, but even then why bother?
Really - this product begs to be machine-assembled: it is simple, but must be totally reliable. All of the problems people had with the Volt Blochers appears to be from poor soldering or mechanical injury (ie - the heatsink getting bumped so it shorts out an adjacent resistor). SMT vastly reduces the chances of such happening and with clever design you can make the pc board the heatsink (at least for a couple of watts).
Heh. You know how to make a small fortune in the controller business? Start with a large fortune and spend it developing and making something that undersells Kelly, who will then come back and undersell you because their parts costs, labor costs and even the Yuan/Dollar exchange rate are all in their overwhelming favor. But hey, good luck anyway!
Jeffrey Jenkins
Old 11-25-2009, 08:04 AM
Dimitri plans on setting up the pots for all the various conditions - I think a person needs a reference supply to set them...
The pot for adjustment of HVC on VBs is set using a simple resistive voltage divider, battery, and dvm. Same should work here.
Dimitri, I believe you said you want to preset everything to eliminate user adjustments/errors. If so, is it more difficult to just give several fixed resistive divider options in place of the adjusting the pots?
Please mount the quad comparator chip in a dip socket rather than soldering the legs directly on the board as the LTV826 chip on VBs.
Regarding mounting on the cell, the VB approach of one rigid contact bolted to the board and one wire seems to work well. The fixed contact supports/holds the board in place, and the wire gives flexibility in routing around any rod for cell hold-downs. A fully rigid mount between terminals has to clear the vent in between them.
I like it! Simple, low current draw, resistor limiting of current in event of a component failure. I agree that hysteresis is desirable. I think it should be smt, ready-to-install, nothing for a user to screw up. The more user intervention, the more headaches for you.
Old 11-25-2009, 08:34 AM
dimitri's Avatar
Everyone, thanks for great comments!
Obviously there are many ways to skin a cat and I tested variety of designs. Russ, I tried your design and it works the same way, but has more components. Main reason for this design is minimum number of discrete components on PCB, which is my main goal, I am minimalist
I don't see a need for more precision, I have 0.01V precision with this circuit, does anyone need more? I observe very little hysteresis, I tried adding feedback and IMHO improvement wasn't worth adding more resistors ( did I mention that I am minimalist ? ).
Dave, your circuit is cool, but I feel that any time / pulse manipulations belong on the head end, cells should report every pulse and be simple. You have way too many components to be on each board, its not practical for mass production. Did I mention that I am minimalist?
I tried to stay away from trimpots, but there are just too many variations of HLVC levels that different people might need, after much consideration I reluctantly came to conclusion to use trimpots to make a product that fits everyone. Calibration can be done by the vendor when customer picks specific values, or by customer, using a simple calibration board which can be sold along with BMS and cost perhaps $10-$15.
As for trimpot adjustment range, LVC trimpot has a good range since reference voltage is right in the middle of typical 2.5V LVC, and HVC and shunt trimpots have their range improved by R3 shifting voltage divison down, I tested it this way and its quite manageable with single turn trimpot, so I don't want to add anymore resistors. Values of R3 vs. trimpots can be selected carefully to further improve the adjustment range, but I feel that 50/50 split should be good enough.
More details in next post, need to step away.....
MiniBMS
Old 11-25-2009, 08:53 AM
KISS principal you are right.. Keep going!
Dave
