Old 05-05-2008, 07:39 AM
emoto emoto is offline
emoto is on a distinguished road
Default My Electric Motorcycle
Here she is:
www.electricmotion.org
Best,
Lennon
Old 05-05-2008, 11:34 PM
ngrimm ngrimm is offline
ngrimm is on a distinguished road
Default Re: My Electric Motorcycle
Seems like a very nicely done conversion. The watt/hour per mile are really down there at 75. How has the Kelly controller been working for you? Norm
Old 05-05-2008, 11:49 PM
mattW's Avatar
mattW mattW is offline
Super Moderator
Wow that's almost exactly the same as the bike I'm planning- same motor, same controller the only difference is I'm planning on using LiFePO4 instead of Lead Acid... Whats the performance like with 300A and how does the motor's brushes stand up during regen?
Old 05-06-2008, 12:43 AM
frodus's Avatar
frodus frodus is offline
also note, that he bought the bike brand new from the dealer without engine
great conversion, well executed. Let us know about the regen. Kelly is still fairly new, and we're eager to hear about it,
Old 05-06-2008, 04:18 AM
Thanks! The odometer is at 400 miles (starting at zero), and everything seems solid. The Kelly controller, Mars motor, etc. all seem to be working very well. Here's a video of the bike in action:
http://youtube.com/watch?v=HWyumTVAQBY
No complaints. I only put things together once, and they've all worked from the beginning.
-Lennon
Old 05-06-2008, 05:47 AM
mattW's Avatar
Super Moderator
What is the reason for the 45mph top speed? is it the rpm limit of the motor at that gear ratio or not enough power or what?
Old 05-06-2008, 06:35 AM
DVR's Avatar
DVR DVR is offline
DVR is on a distinguished road
Nicely Done
Good Job
98% of people will die at some point - Ricky Bobby
Old 05-06-2008, 08:48 AM
There were two reasons for the max speed of 45 MPH:
1) Aerodynamic losses are too high above 45 MPH, so I didn't want to temp myself to waste all my battery juice.
2) I wanted the torque. Since I didn't want a transmission, this required me to have a decent gear ratio. I chose a ratio of 72/12 = 6. The gear ratio essentially determines the top speed (for a given motor, wheel size, etc.)
For both of these issues, check out my Excel spreadsheet calculations:
http://lennonrodgers.googlepages.com...lculations.xls
According to these calcs, the motor has plenty of room to have a faster top-end speed.
-Lennon
Old 05-06-2008, 09:14 AM
p.s. I posted my motor performance plots here:
http://lennonrodgers.googlepages.com...erformance.jpg
Old 05-06-2008, 04:11 PM
Someone on another list asked about a conversion kit. Here's some info:
The bulk of the work was in cutting and re-welding the frame (the
actual welding was done on a weekend). The other parts were quite
easy. And the bulk of the cutting/welding time was spent on a stool
staring at the bike - trying to figure out how things would fit
nicely. The second most difficult part was welding/fabricating the
custom brackets to pinch the batteries - they took an entire weekend
to design and fabricate.
Besides that, this bike is very straight forward for converting
(everything fit like a glove). Note on my website that I give all the
steps to repeat what I did. For example, I only needed 1/4'' steel
spacers for the motor mount, and was able to use the existing engine
mounts. I was amazed to see the chain align properly - after inserting
the spacers. This simplified the motor mounting greatly.
All the instructions are here: www.electricmotion.org
Someone out there could crank these things out in lots - I estimate it
would take about 20 hours of labor each if they were made 5 at a time
(100 hours total). It took me 120 hours of labor for just one - but
that included my calculations, and a lot of thinking time.
The bike cost just under $3,000 to build - all new parts - so there IS
a little room for profit (I'd like to see these things at an
affordable purchase price; ~$4,500 out the door brand new. This way
people would actually start buying them). Note that I found an
operating cost of about 1.5 cents/mile if the cost of the batteries is
ignored, and ~7 cents/mile if the cost of replacing the batteries is
included. This ends up being the same as a very efficient gas
motorcycle. However, the battery cost is included in the initial
purchase (and will likely last 10K miles). Many motorcycles never see
a day past 10K miles (though I find that hard to relate to). My
operating cost estimates can be found here:
Best,
-Lennon
