Old 04-10-2012, 09:57 PM
fb_bf's Avatar
fb_bf fb_bf is offline
fb_bf is on a distinguished road
Default My first run to an empty pack
I just finished finding my true range for the first time. I haven't charged my car since last Wednesday. I've been driving to work and back (10 miles), and to the driving range, again in town. I got home with the odometer reading 67 miles, and I thought I would drive close to my house until my BMS told me I had a cell too low. I drove a route that was mostly 40 to 45 mph, and probably had about 20 stops and starts. I ended up with 101 miles!!! My odometer is off slightly so I think it was really 112 when all done. When the BMS said I had used 80% of the pack, my batteries still read 3.25 volts. I have 38 160AH Thundersky cells in my car. I had my Elithion BMS set up to post a low battery fault at 2.7 volts. I have that signal connected to a light in my dash and to my Soliton Jr. Controller. I had set up the controller so that if the warning light came on, it would only deliver 50 amps. It all worked fine. I was able to get another 3.5 miles out of the car, and there was probably a couple of miles still left. At rest my low cells were reading 2.96 volts. With a 50 amp load they would sag to 2.8 volts.
My cells came from Evolve electrics here in Boulder. They had these used cells from a university that only had 20 cycles on them. When I heard that, I thought these might be a great deal because any really bad cells had probably been culled. I think I was correct. I definitely have a well balanced pack. The highest resting voltage I saw was 3.09 volts. So I think my lightened flywheel, weight reduced bumper, and loosing the luggage rack have paid off.
As you can tell, I'm really excited. I have solar panels on my house, and I looked at my production today. It was 42 Kwh. It's a good time of year for solar. That means in half a day of solar production I can drive 110 miles. (19.6 Kwh pack)
Frank Bernett -- '77 MG Midget, 19.6 Kwh LiFePo, Warp 9 Impulse, Soliton Jr., Elithion BMS
www.electricmgmidget.com
Old 04-10-2012, 11:43 PM
gottdi
Guest
Posts: n/a
Default Re: My first run to an empty pack
Awesome news Frank. Nice to see you have a 100 mile range vehicle. That's better than my Leaf. Great work on the build.
Pete
Old 04-11-2012, 09:41 AM
dladd dladd is offline
dladd is on a distinguished road
Nice build, that is awesome! I can only dream of that kind of efficiency.
home solar is on my summer list, looking forward to that step for sure.
1995 Saturn SL2 ev conversion
Old 04-11-2012, 10:42 AM
skooler's Avatar
skooler skooler is offline
Sweet work!
So what do you think you are getting for WH/mile?
Cheers,
Old 04-11-2012, 01:04 PM
fb_bf's Avatar
Sweet work!
Cheers,
My latest testing using my Soliton Jr. logging showed 183wh/m at 50mph. My commute calculations where estimating at about 196wh/mile. If I use the 19.6Kw pack capacity with 112 miles I get 175 wh/m. I suspect that my actual pack capacity is higher than 19.6Kwh. Remember that I'm driving around at 5000ft which has an air density equal to 85% of sea-level. This is distinct advantage for altitude. Normally ICE cars don't perform as well at altitude due to the lack of oxygen, but for electrics, it's a benefit.
