Re: I need help to figure range before I buy LiFePO4
2 Parallel strings means that you'll double the amp-hour capacity of the batteries you're using while getting half the voltage of the sum of all the batteries:
46 / 2 = 23..
So your pack would be represented as 23s2p (23 batteries per series, 2 parallel strings)
The math is as follows:
Voltage: 72v (3.13V per cell)
Amp Hours: (2 parallel strings of 200AH batteries) = 400AH
Total Pack Watt Hours: 400 * 72 = 28800Wh.
Although, nominal voltage with the same pack would be:
Voltage: 85v (~3.7V per cell)
Total Pack Watt Hours: 400 * 85 = 34000Wh.
Driving distance would be figured out by your average w/mi.
Assuming that you're averaging 300w/mi with a max 80% DOD:
72V pack: 28800/300 = 96 | 96 * 0.80 = 76.8 miles
85V pack: 34000/300 = 113 | 113 * 0.80 = 90.4 miles
Some people have noticed that the Thunder Sky batteries have more capacity than Thunder Sky claims. 40AH batteries sometimes discharge 46AH for example. With 200AH Thunder Sky batteries, you'll probably get a bit more than 200AH and you'll likely exceed 100 miles before 80% DOD.
