Originally Posted by ithinkidontknow
Yes I am building an electric bike, I think you have actually posted on some of my other posts before. It is an electric tadpole trike. Up until recently it has just been all research work but now I am starting to get ready for construction.
Just be *sure* you have it all down and measured out, etc., before you start. I'll tell you from experience that even so you'll end up with lots of lttle things and a few big things that don't go according to plan, and require rethinking--every one of those is going to cost you time and money, but most importantly is going to change *other* things, which will in turn change *others*, and make it feel like planning was worthless.
It isn't.
Without the planning and research, *every* step would probably go that way, instead of just a few of them here and there.
I did reply to some of your other threads; I just wasnt' sure if you were still building the same thing (some people's projects change after their first feedback!).
48v 750w Motor
Yi Yun 48v controller if I can get my hands on the right one
Just remember that you get what you pay for, and those are pretty cheap controllers.
I don't know anything about them other than a bit of googling on their costs and whatnot, and seeing them for around $30-$35 for a "800-1500W" 48V controller sounds pretty cheap, even with the nice-looking aluminum shell.
I'll still stand by the 4QD products, though they are more expensive, they seem to be nearly bulletproof in design. I'm building a 2QD right now, using recycled parts except for the PCB from 4QD themselves. Other than having issues with some of my recycled parts (mostly from old power supplies, UPSs, etc.), it's going pretty well.
Given a few of the parts problems I've had, with shorted transistors, open and shorted diodes, and in one case a capacitor that was sort of marked backwards (the plastic shrinkwrap they use for labelling was loose, and had spun around partway!), I daresay a lot of controllers would have just smoked, probably burning the PCB. Not this one. It just sat there protecting itself, shutdown, until i figured out the problems one by one and replaced parts.
I know for sure (from experience) that the cheap ScootNGo controller I started out with before (and modified, repaired, modified, and repaired some more) would have greeted me with clouds of electronic remains....
Now I am just trying to find a suitable LM339 in my junkpile, as the first one I pulled had one of four comparators not responding to any inputs.
Now, you probably don't want to put a lot of heavy batteries on that 750W version, or you won't get much acceleration out of it. I'd go with a smaller set now, one that will, with that motor, give you the range and speed you want with the estimated GVW you'll have, plus 10% to 20% added as a "oops" factor (because of things you may have to add or beef up on the frame, suspension, etc, as you test it out).
This is my plan for "bike version" which I plan to build to stay under the Washington laws for electrically assisted bicycles. However, after I build the version with the above components, I plan to try to get a moped registration filed with the DMV so then I will be able to go 30mph on roads and have up to 2hp. At that point I would like to install another 750w motor.
But as I am sure you know, this will eat up serious amounts of energy! For this reason, I need some bigger batteries.
True--but I recommend that you do that in two smaller sets of batteries, potentially one for each motor, and possibly a separate controller for each motor, both of which can be run from one throttle (with some tweaking, perhaps).
That way you can start out with one motor plus a set of batteries sized for that motor to be able to easily pull around, then just add a second set once you're ready.
Now to respond to some of your suggestions. Unfortunately, I don't know if I have time to look into freebies just because I am on a fairly limited time schedule as I will go back to school in the fall. If anyone in the Seattle area has an ideas of where to get cheap batteries like this, please let me know! I am really just looking to buy something anyway so that I can expect it to last a long time.
Fair enough. It's just difficult at best to get *good* new batteries cheaply, especially since you want to find the lightest ones that give the most power over the longest period.
Even within lead-acids, there are a lot of types, and some are better than others for each application.
I was looking at a battery manufacturer that makes deep cycles in my area and I can get 12v 85Ah batteries for 80 dollars a piece and they weigh around 40 pounds. Unfortunately, 4 of these is going to be quite a bit of weight (not to mention space) which is not ideal. I remember hearing something about voltage multipliers but this appears to be only for AC to DC conversion but maybe there is something I don't know.
You can do voltage multipliers any way you want, but you'll be cutting the current proportionally to the voltage increase. If you double the voltage, you'll halve the current, since your power source the multiplier is powered from can only produce so much power total.
This yahoo group is supposed to have a good converter circuit in it's archives, according to Joseph (the circuit creator), though I have not yet tried out any of the circuits there.
http://tech.groups.yahoo.com/group/switchmode/
As for those big batteries, that *is* a lot of weight. 160 pounds, plus battery boxes capable of carrying that weight and hardware to attach them (10-20 pounds?), is very significant in a small EV like this. Your frame, suspension, and tires will all have to handle that, plus anything else on it and it's own weight. Not to mention that 750W isn't much to pull all that with.
I'll shortly have a ~650W motor on my CrazyBike, run by the 2QD controller. It'll be around 120 pounds total, plus my 150 pounds, and another 10 pounds or so of stuff I usually carry with me. So I can give you some performance data from that once I test it. I am guessing based on my previous ~350W motor that I should get about the same top speed (same end gearing result), but that my acceleration should increase.
Previously just to get started took much more leg force/pedals than I wanted, so this motor should help. It's also a 4pole motor, vs the 2pole I had before. More torque, less speed. Also more energy consumed, but I need to be able to get started much faster than I can now.
I would love to stop doing research and start the building but it seems like there is more work to be done
It can get depressing to do nothing but research and study when just building a project would be more fun and feels more productive. But I not all that long ago wrote a blog post about how I ought to do *more* research before starting something, since so often I end up changing things afterward to the point where I might as well never have done the first two or three versions of something. If I'd researched or even just thought about it a little more, I'd've saved a lot of time and work, but most of all I'd've saved the parts for other uses (which in your case are going to cost you money).
________
Glass Pipes
