Old 06-11-2012, 08:19 PM
spring spring is offline
spring is on a distinguished road
Default New Case for Kelly controls assembly
The new box is dedicated to the KDZ/KDC/PM assembly including the shunt inside.But It is only useful for the assemblies below,nothing else.
1.KDZ/KDC Sep/ex motor controller assembly
2.KDZ/KDC Series wound motor/PM brushed motor controller assembly without reversing contactor
3.PM brushed motor controller assembly
On the other hand,we will publish one more new box for other assemblies according to the requirements in the near future.
This new box provides friendly I/O ports for customers to hook up the system between the motor,battery pack and the assembly.It can protect the assembly against the dirty or rain.
Old 06-11-2012, 11:59 PM
Default Re: New Case for Kelly controls assembly
Neat. Does this mean the little fans on top of the controller are useless or is there a way to flow air to them?
Old 06-14-2012, 08:18 PM
A very high power controller can not be installed inside the box.Only controller with 450A-500A peak can be used.And we put the silica grease at the bottom of the controller.
The whole system is installed on the aluminum plate.It will be prefered if you can install the heat sink at the bottom of the aluminum plate.
