Old 03-12-2009, 04:39 AM
Tesseract's Avatar
Tesseract is on a distinguished road
Default New controller prototype
The controller enclosure being machined:
Next is the topside view (mostly-assembled, coolant passages not yet milled). We aren't 100% thrilled with the fans but the internal copper heat-spreader for the IGBT module(s) does increase the effectiveness of the heatsink, and the calculated volume of air required to limit the temperature rise of the heatsink to 25C with 1000W dissipated is only 45cfm; those two rinky-dink fans each move 44cfm so with an allowance for backpressure they will technically work fine (and 1000W is pretty much the worst case scenario).
Next is a view of the laminated bus structure made from two pieces of 0.090" thick copper plate and 10mil mylar for insulation. Notice in the lower left hand corner there are two EV200 contactors installed (for a two-module controller - only one will be used for the one-module version). This allows the microcontroller to supervise pre-charging the film capacitor (hidden under the bus plates) as well as protect against hooking up the battery pack backwards, exceeding the allowed input voltage or catching on fire should the output section blow up...
Finally, a close-up of the interface section, showing the industrial ethernet jack (the matching housing for the plug can be installed "in the field" without any special tools), LEDs for power/status and error codes, and sealed barrier strips for 12V power, throttle, contactor interrupt ("E-Stop"), coolant pump, tachometer, etc...
Now I just need to finish designing the new pc boards for this beast...
Old 03-12-2009, 05:05 AM
ga2500ev ga2500ev is offline
ga2500ev is on a distinguished road
Default Re: New controller prototype
Impressive!
ga2500ev
Old 03-12-2009, 05:25 AM
dimitri's Avatar
dimitri dimitri is offline
I am drooling on the keyboard as I type this
There is an empty spot in my EV that wants to be filled by this baby
MiniBMS
E-Protege5 in the Garage
www.cleanpowerauto.com
Old 03-12-2009, 05:53 AM
TheSGC TheSGC is online now
Just WOW. Can't wait to see that thing in action. Let us know if you need any 3rd party testing, I bet this thing will be amazing compared to my 96 volt Kelly.
Old 03-12-2009, 08:47 AM
ClintK's Avatar
ClintK ClintK is offline
Very beautiful! You're like the Steve Jobs of motor controllers (meant as a compliment).
Old 03-12-2009, 08:59 AM
Qer's Avatar
Qer Qer is offline
Send a message via ICQ to Qer Send a message via MSN to Qer
As long as you don't call us the Windows Vista of motor controllers...
Soliton-Motors: 7-0
Old 03-13-2009, 06:56 AM
Hi Tesser,
Nice looking gadget. You might want to have those copper plates plated. I have used tin for copper bus bars.
Keep at it.
Old 03-13-2009, 07:04 AM
JRP3's Avatar
JRP3 JRP3 is online now
Nice, what are the physical dimensions?
Old 03-13-2009, 08:05 AM
judebert's Avatar
judebert judebert is offline
judebert is on a distinguished road
Just here to vote for the name: Hemi.
"You got a Hemi in that thing?"
Awww, yeah.
Old 03-13-2009, 08:43 AM
etischer etischer is offline
Wow, that is pretty sweet. nice attention to detail. Does one fan blow in and the other blow out? You're a great inspiration to all us diy folks.
