Yes, we're still alive. Yes, we're still working on the controller. Yes, things are still being improved. Today Tesseract and Seb tried out a new feature, power limit!
What you see here is an example of Tesseracts sense of humour. When Seb let go of the throttle (at about 462) Tesseract reduced maximum power to 20 kW which meant that Seb suddenly were driving a snail. Then, at around 513 or so, Tesseract restored power while throttle were still engaged! maniac!
(note: I don't recommend messing with the parameters while the controller's running, but they were, after all, testing things and thus have my forgiveness)
So this is how the different limitations for the motor corresponds.
There's of course RPM-limit too, but that didn't really fit into the graph...
The reason for "chipping off" a corner of the power cube is of course that high voltage AND high current is very stressful for the motor, thus this little feature has been on my todo list for a while and since I've added an output setting for a power meter on the dashboard it kinda made sense to add a power limit so the meter knows what range it should use for 0-100%.
I guess I should start looking at SoC too now...
...or perhaps I should sleep. It's midnight in Sweden right now...
