ZX-E, Major, Can you guys help simulate this one?
I hope to eventually convert a 1992 Lexus SC400 to an electric drag car on the cheap. There are better choices, but this is just a fun calculation for now.
I will be using a 350lb GE
5BT1378B6 13" Motor.
The nameplate gives 140ft/lbs of torque at 925 rpm, 48 volts, and 467 amps. I hope to use 14, 12V optima yellow tops to get around 140 volts and 900Amp capability for the length of a 1/4 mile run. I think I will limit the motor to 4000 rpm. I dont have good information on torque at other rpm, and amp ranges. The best I have is a 72V graph for a Warp13. Major-can you help estimate what would happen at double nameplate amps and triple nameplate volts? Here is the Graph for the WarP motor:
Wow that is a big graph, sorry!
For this exercise lets assume I have a controller that can survive this.
The transmission is a powerglide with a first gear that can be either 1.76/1, 1.82/1, or 2.0/1, and a second gear of 1/1. Lets assume 1.82 for this exercise.
The final drive is either 3.62 or 3.29. Lets use 3.62.
The tire size is 225/55/16.
The coefficeint of drag is .31
The weight will be approximately 3800lbs.
I guess we assume perfect traction as well?
Thanks guys,
Josh
