Old 11-06-2009, 12:26 PM
Big-Foot's Avatar
Big-Foot Big-Foot is offline
Big-Foot is on a distinguished road
Arrow OCC - Electric Chopper for Siemens
Just watched it on the tube last night..
Now that was one radically sweet looking machine!!!
They didn't have much on performance information or the programming of the controller like I was hoping.
Was said to have a 60 mile range (if I recall correctly) - as well as more than 100 MPH top end (a lot faster than I would have thought given the apparent gearing)..
My eNinja project may have to wait now!!!
Regards - Randy
GT40 Replica in progress http://www.GT-Forty.com
Old 12-09-2009, 07:04 AM
gtdave's Avatar
gtdave gtdave is offline
gtdave is on a distinguished road
Default Re: OCC - Electric Chopper for Siemens
That looks amazing, surely it must be running a high voltage if they are quoting 100mph, and for a 60 mile range wouldnt they be needing a fair few battery packs wired up to achieve such performance? If so they have either been very well hidden, are extremely small, or the bike doesnt achieve that sort of range and speeds.
Old 12-09-2009, 06:15 PM
spdas spdas is offline
spdas is on a distinguished road
Aloha, they exaggerated, Under the hood it is very low-tech.
but looks good.
Francis
Old 12-09-2009, 08:00 PM
Big-Foot's Avatar
I believed that they did do some exaggeration.
It may well do 100 MPH, but it won't do 100 MPH and have a 60 mile range.
Low tech? I don't think so. Just because it uses an integrated controller module and Charging system - I would not call it low tech. On the contrary. When considering the very basic ICE world of Choppers, this is a very hi-tech piece of work.
Another pic here of the completed bike;
Specs and info;
General Features
• First custom electric American Chopper ((Not so sure about this statement - Randy))
• Made from new and recycled materials
• LED lighting by OSRAM SYLVANIA, a Siemens company
• Range of 60 miles on a single charge
• On-board charger that can be plugged into any 110-volt outlet; recharge time of 5 hours (1-2 hours with a charging station.)
Technical Specifications
• Engine: Type Advanced DC Motors Inc. series wound 8-inch motor with 27 peak horsepower and 72-96 volts peak electrical output
• Battery: Type 72-volt DieHard AGM batteries (96 12-volt cells) Capacity 72 volts with input standard 110V
• Transmission: Direct drive Clutchless one-speed with 4:1 dual-chain drive
• Chassis/Suspension: Rigid frame
• Brakes: Front Brakes are fully hydraulic, stainless steel dual disc (hand controlled); Rear Brakes are fully hydraulic, stainless steel dual disc (foot controlled)
• Front Tire 21 x 3.5 Metzeler and Rear Tire 18 x 10.5 (300mm) Metzeler
• Wheelbase 120 inches and head angle 40 degrees plus 5 in trees
• Frame approx. 75 lbs; total weight about 700 lbs
Regards - Randy
Old 12-10-2009, 05:54 AM
RoughRider RoughRider is offline
RoughRider is on a distinguished road
LOOOL...physicaly it is NOT possible to go 100mph with only 27HP...
LeadAcid-batteries....====>>> LowTech...
60miles range with leadacid...LOOOL
everything, what OCC is doing in LowTech...
Old 12-10-2009, 06:51 AM
kek_63's Avatar
kek_63 kek_63 is offline
kek_63 is on a distinguished road
I take exception to that "First custom electric chopper" statement; and I know mine wasn't the first either.
Keith
Better than a kick in the ass with a frozen muk-luk!
Old 12-10-2009, 07:43 AM
Big-Foot's Avatar
And by what do you base this opinion?
AGM is a long step up from simple wet system Lead-Acid. Certainly not to the degree of lion though..
Many EVs will go a very long ways on level ground and reasonable speeds and temperatures. This is probably a stretch of the truth for real world - but for perfect conditions, it's achievable.
Show us your HIGH-Tech so we have a point of reference please.
Regards - Randy
Old 12-10-2009, 08:20 AM
there are some basic equations to calculate the power that you need, to drive a defined speed...you can get this equations from every good physic-book...
i am not saying, that i have high-tech in my garage...
BUT..this OCC-thing is far away from high-tech
Old 12-10-2009, 08:32 AM
etischer etischer is offline
Siemens was an OEM for AC motors and inverters for companies like VW and Ford. I think the technology in this DC bike is pathetic and so 1980s. I love how they mention that a Siemens company made the LEDs on the bike, why didn't Siemens provide an AC servo motor and controls?
Maybe the Osram LED company can hire someone to build a fancy flash light using incandcent bulbs and AA batteries made by one of their parent companies.
Old 12-10-2009, 08:37 AM
It is a TV show. Entertainment
