Old 05-30-2012, 07:14 AM
swoozle swoozle is offline
swoozle is on a distinguished road
Default Re: Open Revolt with IGBT driver blew IGBTs
Originally Posted by evimarn View Post
Hi any links please as doing a search seems leading to nowhere.
Thanks for the expert help .
http://www.evbmw.com/
Old 05-30-2012, 08:39 AM
evimarn evimarn is offline
evimarn is on a distinguished road
Originally Posted by swoozle View Post
Hi thanks just what I was looking for.);
Old 05-31-2012, 08:22 AM
JRoque JRoque is offline
JRoque is on a distinguished road
Hi. Someone already mentioned but I would add your bulk capacitance bank even when just testing. Good luck!
JR
Old 05-31-2012, 09:05 AM
z_power z_power is offline
z_power is on a distinguished road
There's a lot of useful information about driver circuits in Semikron's application notes AN7002 and AN7003, easy to find in internet.
Old 05-31-2012, 12:51 PM
Yes, those look very useful, thanks.
Old 06-09-2012, 03:28 PM
OK, new IGBTs and some experiments. Please take a look and help us understand what's going on.
These are all one IGBT with a 12V battery source running a starter motor.
All have the same time scale and V scale except the last trace (V scale increased to show the driver signal, time scale the same).
C-E trace, no snubbers, increasing but low PWM, amps probably around 20
One snubber added.
Two snubbers added (though one had long leads)
same with stable PWM somewhere around 50%, current at ~35amps
The drive signal with 12V source and starter motor load.
The snubber. They came with the used IGBTs and we can't find any info on it.
Old 06-09-2012, 03:39 PM
cpate cpate is offline
cpate is on a distinguished road
So we don't really understand why our voltage traces don't look like those shown in other people's pictures of their oscilloscopes when testing their controllers. But we're pretty confident that the snubbers are helping. The first snubber that we added, with extra short leads, helped a lot. The second one, which had the standard leads that were about .75" longer, helped less. I looked around for better snubbers and I found these:
http://www.digikey.com/product-detai...240-ND/2783740
2.9 mOhm ESR, 29 amp ripple current rating, 5 microfarads. These have about 5x the capacitance of the ASC snubbers that we have, but I don't know if their ripple current rating/inductance/resistance is any better. Do you guys think that these will quell the voltage spikes to acceptable levels?
Old 06-09-2012, 03:42 PM
subcooledheatpump's Avatar
Am I reading that scope correctly? It seems you are jumping up to 60 volts during turn off
Have you added any bulk capacitance?
What gate resistor this time? It looks like it's not fully saturating the IGBT
Old 06-09-2012, 04:22 PM
Yup 60 volts or higher seems to be the spike level when the motor is starting. We haven't added any bulk capacitance, just stuck with the round 400v 380uf cap and added the snubbers. The gate resistor is up to 11.2 ohms + .56 ohms on the emitter. Hmm what does a non-saturated IGBT look like? The curve downwards after the spike?
Old 06-09-2012, 05:27 PM
The C-E should look roughly like the gate drive signal
The IGBT Should be on for the duration of the pulse, that should look like a flat line. Then it should almost instantly fall to zero, another flat line. Just like the gate signal.
Personally, I would add some big capacitors to that, keep the snubber, but add some 6000 microfarad capacitors, rated at 400 volts. change the gate resistor to a slightly lower value, 10 ohms, then try again with the same setup. You really shouldn't be spiking that high with only 12 volts. It should really not spike above 15 volts.
