Old 05-26-2008, 02:38 PM
unclematt unclematt is offline
unclematt is on a distinguished road
Send a message via Yahoo to unclematt
Default open source hub motor/wheel motor
Hi All,
There was another thread where we have discussed the need for an open source wheel motor. The wheel motors that are currently in the media are not available to the public unless you want to spend obscene amounts of money, if even then. So I think it would be great for all of us to collaborate on creating an open source set of plans to enable EVers to create their own wheel motors.
So lets start the show:
1) We need a list of objectives to meet with our wheel motor.
2) We need sources for raw materials and components.
3) We also need to find or design controllers to run our wheel motor.
So please offer links and expertise to accomplish this.
I personally think we need a brushless motor, and it needs to put out at least 40kW of power. It also needs regenerative capability, and if possible I would like to do away with friction brakes entirely.
Let the creativity begin!
:-D
Old 05-27-2008, 09:33 AM
JRK5150 JRK5150 is offline
JRK5150 is on a distinguished road
Default Re: open source hub motor/wheel motor
I agree, open source is the best way to go for us all! Designing wheel motors should be fairly straight forward. The real issue is in designing an appropriate controller that can act as a controller as well as keeping all of the motors moving EXACTLY in accordance with the others. I suggest we expand this to an open source wheel motor drive system with emphasis on a safe controller. Since we would be designing a controller from scratch anyway, I feel AC would meet the goals better than DC. With AC we could have a brushless system with Regenerative Braking, ABS, traction control and it would be more efficient. May I further suggest that we focus on writing the control program first (test it with existing hardware), then focus on building our open source hardware. I think this is a great idea and would like to help out any way I can!
-John
Old 05-27-2008, 10:32 AM
CNCRouterman CNCRouterman is offline
CNCRouterman is on a distinguished road
I like the open source concept, though I think making it more universal is more appealing.
Wheel Hub motors are, by definition, in the wheel... So, that would mean that the weight of the wheel will be greater than a conventional wheel design. The higher the capacity of the motor, the more it is likely to weigh.
Given the above, a wheel hub motor would seem more applicable to low speed use, or applications where suspensions are a secondary consideration, due to the inherently higher un-sprung weight.
I agree than defining the objectives of the motor are important at the start.
I think a wheel hub motor would be well suited for applications such as garden tractors, material haulers, electric mule, forklift, etc. 40kw would be overkill for most of these applications. However, I have read on the website of one manufacturer of wheel hub motors, that they can be mounted inboard of the wheel, and couple to the wheel though a drive axle (one motor, one wheel). That makes sense to me in terms of keeping unsprung weight down, even using one to drive a conventional auto RWD axle, keeping the differential, or two for 4WD.
I suggest keeping conventional mechanical brakes because at some rpm point, it will take energy to slow it anymore, and it will definitely require energy to hold position against an outside load, so for full stop or parking, conventional brake are hard to beat.
With regards to the controller. I am very interested in learning more about design and building a controller for my future EV project. I have found that there are many electrical CAD packages out there, I found one called Dipfree 1.5 which has a freeware version. As I am pretty ignorant about integrated circuits at this point, I don't know if it will help in design and understanding. I am quite familiar with CAD/CAM software for use in CNC routing, so I know that mere possession of a tool does not equate to proficiency with the tool. I do hope, however, that possession of this electric design tool will help me learn. I have been watching another thread on this board regarding an AC 3 phase controller, but it is still mostly over my head technically.
Eric Neumann
CNC RouterWorks
http://www.cncrouterworks.com
Old 05-27-2008, 10:35 AM
thesilverring thesilverring is offline
thesilverring is on a distinguished road
Does anybody have an IEEE membership? If so you could view this article. I actually went to Bath Uni and went to this guy's lectures - but at the time I was not so interested. Going to uni when you are 18 years old to actually learn the material in a degree course is not the best idea.
This is the sort of thing you are talking about right?
http://ieeexplore.ieee.org/xpl/freea...isnumber=10700
A couple of the guys working on this stuff were decent chaps - Prof Dave Rodger (Scottish guy who looks more like Billy Connolly than Billy Connolly). Paul (?) Leonard and some other chap who's name escapes me right now. Anyway, they developed some Finite Element Analysis software to model electro-magnetics - specifically for motors.
About all I remember from the Motor design courses are Gaussian beer cans, the model Doc Rogers used to teach field theory.
Old 05-27-2008, 04:28 PM
Manntis's Avatar
Manntis Manntis is offline
Manntis is on a distinguished road
Good lead - and an interesting paper Unfortunately such an axial flux motor, IMHO, adds sprung weight in the form of the greater diameter of fixed magnets and the diagrams seem to underestimate the amount of travel required by the rotating mass in suspension compression and suspension extension conditions. Covering the complete range of motion would necessitate placing the bottom of the (rather expensive) magnet housing assembly very close to the road and because of its hard mounting position it would not be able to softly deflect from road debris encountered while in suspension compression. The potential for damage could be very high indeed.
Old 05-27-2008, 08:44 PM
So how will we decide which basic design is best to follow? What power output is being targeted would be good to figure out as well.
If people could do a mini-presentation on the design they are promoting, that would help the rest of us get up to speed on their proposal. Links to photos/articles and text should do fine.
Question: should the controller be able to fit in the stator of the motor? If space is left for this in the center of the motor, will that cause problem with flux distribution or saturation?
Some informative links:
http://groups.yahoo.com/group/lrk-torquemax/
http://www.wavecrestlabs.com/automot...wheelmotor.php
http://www.youtube.com/watch?v=8tLQ2-yKT4Y
Old 05-28-2008, 01:34 PM
judebert's Avatar
judebert judebert is offline
judebert is on a distinguished road
I always thought it would be interesting to put magnets in the rotor, and outfit the calipers with windings. You could get propulsion, regen, and friction braking all in the same place.
Old 06-01-2008, 01:51 PM
Originally Posted by JRK5150 View Post
Since we would be designing a controller from scratch anyway, I feel AC would meet the goals better than DC. With AC we could have a brushless system with regenerative braking, ABS, traction control and it would be more efficient.
-John
Hey John,
When you wrote this, were you thinking of AC at 60kHz, or DC delivered in an alternating way with a controller (brushless DC motor) ? Or exactly what?
If you have any diagrams or links, please post. thanks.
Old 03-06-2009, 06:21 AM
lpite lpite is offline
lpite is on a distinguished road
Easier to make a conventional wheel motor with a separate brake rotor for mechanical braking. Or make the rim itself the motor spinning on a fixed hub.
Baby Products On Sale
Old 05-29-2009, 02:10 AM
brdriver brdriver is offline
brdriver is on a distinguished road
Send a message via MSN to brdriver
Talking Re: open source hub motor/wheel motor
advice you use BLDC motor control system.it is the best of solution on all driver of EV.you can try know Bangrong rechnology's product,maybe you will find new benefit on enterprise.
tks!
best regards!
I agree, open source is the best way to go for us all! Designing wheel motors should be fairly straight forward. The real issue is in designing an appropriate controller that can act as a controller as well as keeping all of the motors moving EXACTLY in accordance with the others. I suggest we expand this to an open source wheel motor drive system with emphasis on a safe controller. Since we would be designing a controller from scratch anyway, I feel AC would meet the goals better than DC. With AC we could have a brushless system with regenerative braking, ABS, traction control and it would be more efficient. May I further suggest that we focus on writing the control program first (test it with existing hardware), then focus on building our open source hardware. I think this is a great idea and would like to help out any way I can!
-John
