Originally Posted by 3dplane
Bowser!
I know your question is not directed at me but the way I see it is the easy and cheap part of this is to actually build the motor. My question is : what are we going to use for controller and how much does it cost? I know I can't build one!
Originally Posted by Gravitic Anomaly
A controller for a PM brushless motor is easier to build than an AC vector drive. A industrial vector drive can be used to run a PM brushless motor if it has the right software. Many of the higher end ones have this built into them.
I would like to make my part in this project clear. I'm a programmer, by trade and inclination. I have experience in many computer languages, almost entirely C or higher-level, but a very little embedded and real-time experience.
I am formally offering to donate my programming time for
any controller designed for use in a highway-capable electric vehicle, under one condition: anyone must be allowed to use and modify the resulting code. (Like the GPL.)
I can design a suitable drive for the motor. We need an experianced board designer and electronics prototype guy to do the hardware.
You build the motor, someone else builds the controller, and I'll program it. Where are our electronics guys?
Rather than trying to upscale an existing design you are better off designing from scratch.
The other controller designers on the forum (or is it the EVDL?) seem to think differently. I don't know enough about it to say.
I think the simplest motor would be a PM brushless motor built onto a manual transmision/transaxle. The stator assembly would be bolted to the transmission housing and the rotor would be attached to the transmission input spline. This way the builder does not need to make housings, shafts, or add bearings. All the pecision machining is already done.
Interesting idea. I kinda like it. It doesn't take advantage of the previously stated advantage of brushless DC (good torque at low RPM), but it's definitely the elegant solution.
I'll restate my ACIM preference, while I'm here. For my own selfish reasons, I would prefer a motor as maintenance free as possible. That means no brushes. I understand ACIM better than brushless DC, but only barely. I'll still be happy to program a brushless DC controller, too.
I'd also like regen, and a smart charger built into the inverter/controller.
If we were doing requirements analysis like we do on software projects, I'd want:
- The drive system shall be maintenance free after installation.
- The drive system shall operate the vehicle from stationary to top speed without requiring the driver to shift.
- The drive system shall recharge the energy storage system using energy recaptured during braking.
- The drive system shall recharge the energy storage system using energy provided from an electrical outlet.
That's what I'm willing to work for. Design me a system that fulfills those requirements, and I'll be staying up late to program it for you.
