Originally Posted by Nsharit
Originally Posted by tj4fa
Maybe Ken could make an inline plug-in modular box?
Wouldn't the entire system be safe from EMF if shielded wires were used? I kinda figured that would be standard for any discrete indication wiring.
Possibly, but all EV builds components, wiring, ect are not the same and the "dirty" environments have different frequencies and different types of EMI (magnetic/electric). Apparently, some EV builds have no problems at all, while a few others have.
That's why I think a plug-in module that can be easily connected between the existing wiring may be the easier way to go if there has been a lot of the units already fabricated.
It seems like the best cure right now is something filtering the EMI in the final wiring close to the indicator itself whether it be the method Dimitri found earlier in this thread or someone else found in this thread:
http://visforvoltage.org/forum/2987-paktrakr-data-noise
Perhaps shielded twisted pairs installed in the final wire segment inside the passenger compartment from the Paktrakr display unit to the next Paktrakr junction box being may do the trick.
[PJ-box] = Plug-in Passenger compartment J-box
Meter------[ PJ-box ]------shielded pr------[ PJ-box ]--------[ Last battery J-box ]
Unfortunately, I don't have the system to give this a try.
Here is a good article about EMI and filtering that might be of value.
http://www.woodward.com/PDF/IC/50532.PDF
