Old 03-03-2010, 11:26 PM
olds olds is offline
olds is on a distinguished road
Default Performance EV, questions
Hello everyone, I'm new to the EV scene but not to cars. I'm getting tired of the same old engine swaps and forced induction, etc. I need something new and I like what I see on here and the potential of electric vehicles.
Could someone point me to a site or postings that have information on building a EV performance/all around vehicle?
Is it possible to drive 2 or more electric DC engines in one application, using an otherwise unmodified manual transmission? Everywhere I look on the net shows how to build one electric engine mated to one tranny, and the most powerful DC engine I've yet to find are 500-600hp. This was an industrial engine, is it possible to vary the voltage to this engine so that it consumes less power in everyday driving situations? I have seen a KTA kit which has DC power ratings for 'continuous' and 'peak' power that I haven't found in industrial motors.
Please educate me on this. The ultimate goal would be a car able to run in the 11's or low 12's (1/4 mile) and have enough range when out of the throttle to reach 100-200miles. Is this possible? Would I need multiple electric engines? What type of battery options should I be looking at for this? How many deep cycle batteries vs. dry cell vs. lithium ion laptop-type batteries would it need? What is the advantage of each? This vehicle without an engine would be around 2600lbs.
Old 03-04-2010, 04:39 AM
Default Re: Performance EV, questions
Welcome olds,
I suggest you search for "White Zombie" and "Crazyhorse Pinto" on this forum as well as the web. Also check out the association site NEDRA.
You should find answers to most of your questions. Both John and Mike have documented their builds well on their web sites.
Old 03-04-2010, 05:59 AM
EV-propulsion.com EV-propulsion.com is offline
EV-propulsion.com is on a distinguished road
Hi Olds,
We or any Netgain motor dealer can have a custom built dual motor like this built.....
As far as your 100-200 mile desired range, that high end is really pushing it, unless you want to build a pack like in the tesla.. but that would cost a huge amount..the low end is of course easier on the wallet....
And of course because of the high currents involved, everything is going to have to be top notch quality, so don't expect this to be cheap at all...
Oh, and a lighter car would be a little easier to get that ET
www.EV-propulsion.com
Old 05-31-2010, 03:24 PM
The Toecutter's Avatar
The Toecutter The Toecutter is offline
The Toecutter is on a distinguished road
100-200 miles range is perfecly possible with a small size battery pack, *if* your chassis is aerodynamic enough and uses other efficiency tweaks(like LRR tires, although they won't provide enough traction to get you into the 11s).
What kind of car are you converting? Are you intent on modifying its body to reduce drag?
You have to look at the car you are converting as a complete system. It is usually said with regard to EVs:
"Fast, Long Range, and Cheap. Pick Two of them."
If you have a lightweight/streamlined chassis, you can indeed have all three, with a lot of design work and testing. There are conversions that need less than 120 Wh/mile to maintain highway speeds, such as John Bryan's electric Karmen Ghia, or Reverend Gadget's GT6-bodied Triumph Spitfire. If you decide to use lithium batteries of sorts, such efficiency will dramatically reduce your pack costs for your desired range.
