DIY Electric Car Forums > EV Clubs > Dallas EV Club
Old 10-05-2008, 01:00 PM
MMyers1 MMyers1 is offline
MMyers1 is on a distinguished road
Question Possible donor car
I found the following:
1979 Peugeot Estate
It has a 70hp Diesel with a 4 speed manual transmission. My thoughts are that with the diesel it has a good suspension, the estate gives it plenty of room to place batteries, and the manual transmission, coupled with the deisel means the overall gearing should be prime..
The donor cost is $200.00 and may be negotiable...
Thoughts?
Mark
Old 10-09-2008, 03:22 PM
Zemmo's Avatar
Zemmo Zemmo is offline
Zemmo is on a distinguished road
Default Re: Possible donor car
That looks like it would be a heavy car! But Chet in our club has an Escort Station Wagon EV. So it can be done but I don't remember what performance he gets out of his car. The typical donor car is a compact 2 or 4 door car, light weight and typically aerodynamic.
Old 10-10-2008, 04:44 AM
TexomaEV's Avatar
TexomaEV TexomaEV is offline
Moderator
TexomaEV is on a distinguished road
Smile Re: Possible donor car
At least with that donor, you could still retain all the passenger capacity.
www.nteaa.org
www.flickr.com/mbarkley
Old 02-13-2009, 03:00 PM
electricwagon electricwagon is offline
electricwagon is on a distinguished road
1979 Peugeot Estate
I love wagons. And then the legendary 504. I've owned a 504 sedan some years back. Really great car. Think Mercedes, but with the smoothest suspension you've ever seen. Never owned the wagon, but a co worker had one and he could put a truck load of stuff in it, literally.
On the picture, that is a 504 euro model. Where are you? If it is around Dallas, would have to be a US model with euro headlamps and really early bumpers. Kurb weight for euro model was around 1200Kg. 1800Kg GVWR. Can carry 8 adults. Unless it is the utility version, only 5 adults.
That is not too heavy at all. US models are heavier due to endless gadgets, but they can be made lighter.
For $200 it has to be in bad shape, normally they fetch $500 and end up in africa for parts. Did you end up going for it?
There was also a coupe and convertible, all Pininfarina designed. And the sedan with the very interesting looking trunk. Latin america also got a pickup version.
Of course, if you want to have it serviced, Dallas has the best french car mechanic around, Garage Courtier. They've been around since 1976.
