DIY Electric Car Forums > Production EVs and Hybrids > Production Hybrids
Old 05-07-2009, 08:26 PM
Nomad Nomad is offline
Nomad is on a distinguished road
Default Prius.
I happen to own a prius and have worked inside and out of the car. If anyone needs to know anything about the GenIII's let me know.
Old 05-12-2009, 09:53 PM
arontwo arontwo is offline
arontwo is on a distinguished road
Default Re: Prius.
Try this website...
http://www.toyotapriusbattery.com/
Old 05-13-2009, 10:48 AM
Default Re: Prius.
Think you miss read my post.
Old 06-10-2009, 04:37 PM
ithinkidontknow's Avatar
ithinkidontknow ithinkidontknow is offline
ithinkidontknow is on a distinguished road
Send a message via Yahoo to ithinkidontknow
Default Re: Prius.
I was curious, do you know the horsepower/kW rating for the prius' DC motor?
Old 06-10-2009, 07:11 PM
Default Re: Prius.
If you mean how much HP it gives per kW you give it?
I have no idea.. but I do know that @ 57kW it gives 76HP ~
However acording to Toyota it's between 750watts/HP to 950watts/HP
Old 06-10-2009, 10:12 PM
Default Re: Prius.
I guess what I was wondering is what the maximum/continuous rates for horsepower are for the motor.
Old 06-11-2009, 02:53 AM
Default Re: Prius.
Oh, that I have no idea. Given people have pushed these little DC's pretty far, and the fact they are PMag, I would say you have a pretty good chance of running at max for quite a while without serious burn up. Keep it around 5k rpms and you should be fine.
You might want to check out the PIP forums and see if they have an idea. (plug in prius)
Old 09-29-2009, 02:41 PM
JRitt JRitt is offline
JRitt is on a distinguished road
Default Re: Prius.
The main motor can put out 67hp but the battery is limited to 27hp. I have seen a post from a EV only Prius that it got to 70mph
Old 09-29-2009, 03:01 PM
PhantomPholly's Avatar
Default Re: Prius.
So, if you added a second battery pack and controller in parallel, it would produce nearer it's rated hp?
Old 09-29-2009, 07:14 PM
Default Re: Prius.
here is the UTube video I saw
http://www.youtube.com/watch?v=Qfkvy..._embedded#t=28
