I'm looking to use a Prius A/C compressor (ES18C) in my Miata. I'm running 108v and know that the Prius compressor runs higher but I'm thinking that it should work. My question is does anyone know of a 3 phase brushless controller that does not require the use of tachometer or encoder feedback?
I also have a newer version of the Denso compressor that has the controller built into it (ES27C) but I can't find any data on the communication protocol for it. This compressor is used in many other brands other than Toyota so the control protocol must be published somewhere. If I could find someone with a 2010+ Prius in my area I could use my o-scope to reverse it out too.
There exist many cheap sensorless BLDC controllers (feedback by measuring back EMF over unpowered phase), e.g. Kelly controls. Sensorless BLDC control is also popular in the RC community, but the power (and voltage) requirements for the AC compressor are probably higher?
It arrived today in a bag in bubblewrap in a large shoe with 8 postage stamps totalling £21.25. I didn't know Royal Mail even offered 5GBP stamps.
My ES27C has a tag on it saying 1195899, Google found that number on a partsgateway.co.uk listing by Motorhog, at £92 inc VAT and delivery. It was removed from a 2007 Lexus GS450h (3rd gen S190 2005-2011).
The plugs seem to match those indicated on a Prius Gen3 wiring diagram I found last night, though I can't properly unwrap and inspect it where it was delivered. I haven't yet worked out what what it expects on the 5-pin connector. If BEAN/MPX I've found some info on the frame format (0v/12v signals).
The tall connector (B) is for the E1 orange 2-pin plug, orange shielded HV DC cable to the Converter Inverter Assembly (D) connector, with an E2 White 2-pin plug.
1: "PE" to pin 2 "ACPE"
2: "PB" to pin 1 "ACPB"
Not sure which of "B" and "E" are positive or negative. Don't want to connect 200+ volts backwards.
The lower wider connector (A) is for the D12 black 6-pin (I misremembered above) plug.
The matching connector is a Sumitomo TS-series 6189-1083. This links to the DA1 panel connector then 4 wires to plug A21(A) on "Power Management Control ECU".
1: "CLK" green to DA1:19 to PMC:19 "CLK"
2: "DIN" yellow to DA1:20 to PMC:31 "ETI"
3: "DOUT" red to DA1:21 to PMC:30 "ITE"
4: "STBI" white to DA1:22 to PMC:20 "STB"
5: "GND" white-black to DA1:17 to ground point A4
6: "IG1" violet to DA1:18 to share a 10A fuse in (IG)
The diagram also shows a connection labelled "IDH" at both ends, between Converter Inverter Assembly and A/C Amplifier Assembly. I don't know what A/C Amplifier Assembly does.
I'm not sure what protocol is used between the PMC ECU and the Compressor. PMC ECU has two CAN pairs, but the ITE-DIN and DOUT-ETI naming doesn't match the naming of all the other CAN pairs on the diagram. Everything I've read about BEAN describes it as a 1-wire simplex connection with daisychaining, so it shouldn't need a clock signal and I have no guesses for what STB means.
The lower wider connector (A) is for the D12 black 6-pin (I misremembered above) plug. This links to the DA1 panel connector then 4 wires to plug A21(A) on "Power Management Control ECU".
I found this question, with some musing but no answers;
SPI normally uses 4 wires: select (device pulls it low to become master), clock (drives the slave's reading so it can tell the difference between a long 1 and two adjacent 1s), data one way, data the other.
SPI doesn't define the protocol or the voltages. I might be able to learn something by removing the cover and tracing from the pins to a chip, hopefully a dedicated interfacing chip.
To quote Dave JonesDon't turn it on, take it apart!
Two cross-head screws hold down the metal plate. Mine also has white silicone sealant around the edge. The black plastic under the metal has a notch near each of the screws so you can get in between the plastic and metal.
Under the cover, there is a sticky transparent gloop.
The plastic casing is attached to the main casting by four T25 Torx screws, plus there are a number of Torx and cross-head screws within the gloop.
If you're interested in using the Denso ES compressor for its original purposes, this post won't help you much. I'm interested in the ES27 and ES34 as drive motors for lightweight vehicles, with 6.0kw and 7.4kw ratings respectively. I don't know what the ratings are for the "Old ES27" I have.
The cap is held on by 6 screws, 10mm hex heads, no washers.
Inside, there is an M-shaped rigid flap held on very firmly by a screw with a 5mm Allen head. This is part of what regulates the output pressure of the compressor. Ignore it. The block it's attached to just lifts out to reveal an off-centre bearing with a counter weight. That lifts out too.
The next machined lump should be (from what I've seen here) just a bearing carrier which locates the rotor within the stator. The face is about 31mm in from the surface where the cap seals.
The not-old ES27 motor has a max speed of 8600rpm, but this limit might be because of the radial loading generated by the scroll assembly. Even so, it would be great to fit some amount of reduction gearing inside the original casing, especially given the casing is designed to run the R134a and the ND 11 oil (non-conductive, POE-based) past the stator, so I could use an oil-cooling circuit to keep the motor cool.
The Nissan Leaf uses the same compressor.
I'm keen to use its motor for different purposes.
The compressor uses 1-wire LIN protocol to communicate to the A/C auto amp.
Has anyone sniffed it and decoded it?
Do you have any data on the Leaf A/C compressor motor? I need pole count, max rpm and max continuous power.
I have one unit here on my desk and i am trying to run it with Lebowski controler. I tried to get something from control bus, but it works on a signal level that my computer cant determine. I can see signal on a scope, but i cant talk to it... So i decided to do it the hard way. To build controller designed for that.
Now motor does not want to run since i cant get relevant data for auto tuning code. I think its because i use Volt inverter which is much to big to measure such a small motor.
It seems it's not possible to remove the controller board from the compressor without desoldering some connections. I've succeeded in separating them by brute force, since I haven't been able to identify the sticky transparent gloop and won't be able to document both sides of the board properly without cleaning it off.
There are 6 discrete transistors that are screwed down to use the main housing as a heatsink, but it looks like there are multiple soldering steps during assembly.
Current plan is to retain the 3 fat pins (5-6mm?) which connect the board to the phases as the mount for these pins closes one of the housing openings and I'd like to run coolant through the housing as it originally did, but with an external pump.
Well i have this one that came off a 1st gen leaf.
I managed to run it on 50Vdc and ebike controller just fine. But run with propper power controler doesnt work just yet. I need to know what is the pole count.
This is an interesting project. Getting to run the compressor with that inverter off ofa Prius car, has being the problem I see.
Isn't it possible for you to get both the compressor and inverter of the prius, and figure out how your voltage source can power it?
I'm just being curious here.
The Denso ES compressors have their controller and inverter built into the same casing as the motor and compressor. There are two problems:
1. The control signals aren't documented.
2. If you want to the the motor for something other than spinning the AC compressor, the standard controller will only spin the motor in one direction.
I'm planning to use one of these compressors for my own conversion. I have a 2007 GS450h which I'm using to sniff data between the various systems, I'll have a look at reading the AC compressor data tomorrow.
Edit: Wiring scheme is here. You can see which is in / out.
Here's the expected waveform from the service manual:
I access the wires from part of the engine harness.
I didn't get any sensible data from ETI or STB, so the attached files just have CLK and ITE.
Data is raw, I haven't looked at it yet. Looks like SPI or some variant of it.
Attached files can be opened in Sigrok Pulseview (free software, no hardware required). Just set file type in the Open dialog to all, as I have to save them as .txt to attach them.
I went through some of the data, here are some of the data frames. All are 10 bytes long, and synced to a clock. Very slow data rate on this, each clock cycle is 3.2ms, each byte of data takes 26ms to receive, and each packet of 10 bytes is received over 315ms, with a 80ms gap in between. So less trhan 3 packets per second.
Hi, I'm interested in running the compressor on a table. Since the controller is integrated into the compressor, I'm trying to figure out what I'd need to do to to drive the motor.
Did any of you make any headway on what you'd need to do to operate it?
Thanks in advance.
Hi all, not sure if I will confuse more with this, but we open the Nissan Leaf compressor... of course broken the board so we are now trying to just move the motor. We saw the motor works in 3-phase so we need a PWM from 350VDV to 3-phase and controlling by 12v, looks easy but a month and I couldn't find any circuit done already.
Actually this is the last step converting our Mini R50
88.6K members
