Old 06-09-2010, 12:05 PM
jarvi69 jarvi69 is offline
jarvi69 is on a distinguished road
Default Proyect
Hello to all, I appear am called Javier and live in Spain through the first thing sit very much my English hope that they could understand me.
After reading for some weeks I believe that im going to try to do an EV to me. I have some questions that surely are thousand times raised in the forum but for my basic English I have not found.
First my project:
The car that I want to use its:
MINI MORRIS
MG MGF
FIAT Barchetta
Engine:
AC
V/DC 144V
Max Torque 150
Nominal Torque 48
Max power 30 KW
Nominal power 15 KW
Max rpm 5600
Controller specify for the engine.
Batteries:
It wanted to put batteries of 150 Ah at least. The doubt that me arises is whom buying them. The price that I read for the sites is 1.5 $ Ah more or less but dont say to me price put in my house... I have found a few batteries that I am thinking can I put the specifications they appear in the atachment. What is the specifications I need to see in the batteries?
It wanted that the car was coming to 100 km/h and 100 Km from distance.
That look like to you the cars? I dont know if in the mini can entry all the batteries...
Do you believe I can go to this speed and distance with someone of these cars and 150 Ah or I need more?
Good I wait for his opinions and suggestions
A greeting.
Old 06-09-2010, 01:19 PM
Duxuk Duxuk is offline
Duxuk is on a distinguished road
Default Re: Proyect
Your English is OK. I understood everything you asked! My 72V pack of 110Ah lead acid batteries cost me £600 in Britain. (About $900?) A Mini would make a great EV. Without an engine they are light enough. If you only needed the front seats you could easily fit 12*150Ah batteries. You would also have the boot (trunk) space and the engine compartment. You could keep the transmission and use a WarP9 or similar to easily get the performance you need. Using half your battery energy storage, 100Km would leave you only 180Wh of energy to cover each mile (1.6Km)-not enough,I don't think! Do you REALLY need to travel 100Km? Would half that be enough? Your batteries will weigh about 450Kg. Any more weight than this is a lot for a Mini or any other small car. If you use a bigger car and you need more energy storage. Your range is the limiting factor. If you aim for a SMALLER RANGE it will be MUCH EASIER!
Andrew.
