[quote]On 28 Sep 2009 at 15:25, Eric Poulsen wrote:
> You have the EV equivalent of "volume knob static" as seen in older
> stereo equipment. We used to fix it with something called "Color TV
> Tuner Cleaner" from Radio Shack.
My experience with this stuff is that in the long run it makes matters
worse. One can of spray I got at Radio Shack - which I think was called
exactly that - actually partly dissolved the interior of a pot in an audio
amplifier I had. Vorpal stuff.
The best, safest, and longest-lasting cleaner I know of for potentiometers
(be they in EV or audio use) is the original Cramolin Red. I still have a
tiny bottle of it that I got almost 20 years ago from Caig when they were
distributing it (Caig's current item, Deoxit, is not the same stuff).
You use it very, very sparingly; apply it with the tip of a toothpick
(assuming you can get to the inside of the control). If you use it right,
your kids will inherit your still-mostly-full bottle when you die.
When I checked on it just now, I learned that there is apparently no current
US Cramolin distributor. They seem to have had some kind of falling-out
with Caig (each side says the other was the bad guys). Reportedly you can
buy it directly from the factory in Germany, with really high postage
charges, or from farnell.com in the UK. It's now called Contaclean.
EVDL Administrator
Note: mail sent to "evpost" or "etpost" addresses will not
General EVDL support: http://evdl.org/help/
Archives: http://evdl.org/archive/
