Re: [EVDL] A tear - down of the Volt battery pack
I managed to get as far as leaving a comment and then stopped at "a lithium-ion battery pack ... generates the 16-kWh power"... I guess he meant 'stores' but honestly, how does he get away with it? Very sloppy.
Regards, Martin Winlow
Herts, UK
http://www.evalbum.com/2092
www.winlow.co.uk
[quote] Cor van de Water wrote:
> I stopped reading when the author claimed that the Volt was the
> first production car that could go 40 miles on electricity alone...
> Cor van de Water
> -----Original Message-----
> From: xxx@xxx.xxx.edu [mailto:xxx@xxx.xxx.edu] On
> Behalf Of Rod Hower
> Sent: Friday, August 03, 2012 11:26 AM
> To: Electric Vehicle Discussion List
> Subject: [EVDL] A tear - down of the Volt battery pack
> It appears to be a pretty detailed article (I just browsed through,
> didn't read the entire article)
> http://www.edn.com/design/systems-design/4391497/Teardown--High-voltage-
> Li-ion-battery-stack-management---the-drive-for-safe-power?cid=Newslette
> r+-+EDN+Fun+Friday
URL: http://lists.sjsu.edu/mailman/private/ev/attachments/20120805/2b1b5c78/attachment.html
