Re: [EVDL] TODD PC-45 power converter/charger - DIY Electric Car Forums
Old 03-23-2008, 10:55 AM
Default Re: [EVDL] TODD PC-45 power converter/charger
It should do the job of DC-DC conversion.
I recently bought a Iota DLS 55 amp DC-DC Power Converter on Ebay for
$115.00 buy it now brand new.
It was a great deal. Here's one from the same seller for $140.00 + 15.00
freight.
http://cgi.ebay.com/ebaymotors/Iota-DLS-55-amp-RV-Power-Converter-Battery-Charger-IQ4_W0QQitemZ190207356159QQihZ009QQcategoryZ50073Q QssPageNameZWDVWQQrdZ1QQcmdZViewItem
Item number: 190207356159
Neal
Hi all,
Recently I bought on eBay the TODD PC-45 power converter/charger -
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=130204086958
I want this device as DC-DC converter - somewhere in Internet I saw the info
that it can convert 100-130V DC to 12V DC. But the seller says that it is
AC-DC converter/charger only and he doesn't know if it can work as DC-DC
converter.
So, please, could you help me and give advice if this device can work as
DC-DC converter?
Thank you very much in advance,
Oleg
View this message in context: http://www.nabble.com/TODD-PC-45-power-converter-charger-tp16236939p16237089.html
For subscription options, see
http://lists.sjsu.edu/mailman/listinfo/ev
Old 03-23-2008, 11:08 AM
Hello Neal!
Thank you for reply!
I know about Iota converters - I have one, it is great modern impulse DC/AC
to DC converter.
But this TODD PC-45 is older and may have different desing that could not
allow the DC-DC convertion...
I wonder if somebody have some expirience with TODD PC-45?
Oleg
> freight.
> Neal
> Hi all,
> info that it can convert 100-130V DC to 12V DC. But the seller says that
> it is AC-DC converter/charger only and he doesn't know if it can work as
> DC-DC converter.
> DC-DC converter?
> Regards,
> Oleg
View this message in context: http://www.nabble.com/TODD-PC-45-power-converter-charger-tp16236939p16237389.html
Old 03-23-2008, 11:39 AM
I had a Todd PC-20 that worked fine as a DC/DC converter until it died a few
months ago.
Neal
[quote]electroauto.ru wrote:
> Hello Neal!
> DC/AC to DC converter.
> Regards,
> Oleg
>> freight.
>> Neal
>> Hi all,
>> DC-DC converter.
>> DC-DC converter?
>> Regards,
>> Oleg
View this message in context: http://www.nabble.com/TODD-PC-45-power-converter-charger-tp16236939p16237759.html
Old 03-23-2008, 12:20 PM
What is your pack voltage?
For a standard 110V AC supply to work well,
it should get between 130 and 180V DC.
Usually the capacitors in the 110V devices
are rated for 200V, so you should stay under
that at all times.
If you run the DC/DC while charging, then you
must make sure that your peak charge voltage is
lower than 200V, so you cannot use more than a
156V nominal pack, otherwise you can never do an
equalization charge.
If you run a 120V pack, this device may still work
but it may draw more current at the primary side, so
keep an eye on the temperature of the switching FET.
During deep voltage dips (accelerating when the
pack is getting empty) the DC/DC may brown out and
you need to accept that all accessories are running
from your 12V battery. Check that your device does
automatically recover from such a situation once
the pack voltage rises again.
Hope this helps,
Cor van de Water
Systems Architect
Skype: cor_van_de_water IM: xxx@xxx.xxx
Tel: +1 408 542 5225 VoIP: +31 20 3987567 FWD# 25925
Fax: +1 408 731 3675 eFAX: +31-87-784-1130
Second Life: www.secondlife.com/?u=3b42cb3f4ae249319edb487991c30acb
-----Original Message-----
From: xxx@xxx.xxx.edu [mailto:xxx@xxx.xxx.edu] On Behalf Of electroauto.ru
Sent: Sunday, March 23, 2008 8:46 PM
To: xxx@xxx.xxx.edu
Subject: [EVDL] TODD PC-45 power converter/charger
Hi all,
I want this device as DC-DC converter - somewhere in Internet I saw the info that it can convert 100-130V DC to 12V DC. But the seller says that it is AC-DC converter/charger only and he doesn't know if it can work as DC-DC converter.
So, please, could you help me and give advice if this device can work as DC-DC converter?
Oleg
View this message in context: http://www.nabble.com/TODD-PC-45-power-converter-charger-tp16236939p16236939.html
Old 03-23-2008, 12:57 PM
The ordinary Todds didn't work well at 100-130V, they used to made a LV
version just for us EVers.
However they quit making that a few years ago and around the same time
switch to a new version of their converters. The new ones use a voltage
doubler to convert 120V AC into 240V AC and then rectify and convert this
voltage.
The gist is that the newer versions of the Todd are not at all compatible
with low voltage conversions, however they might work with high voltage
(240+ volts DC).
I don't know if you have the old version or the new version, I quit
bothering to keep up with them a long time ago.
If it is the old version, it might work at reduced capacity with only 100
V input, or it might burn out. There were a few folks that used to
convert the old versions to LV versions. As I recall it had something to
do with adding a few coils to the main transformers inside.
> Hi all,
> info
> converter.
> DC-DC converter?
> Regards,
> Oleg
> Nabble.com.
Old 03-23-2008, 03:06 PM
Thank you all!
My battery pack voltage will be 144V-156V, so I guess it should work fine.
> that at all times.
> Hope this helps,
> Cor van de Water
> Systems Architect
> To: xxx@xxx.xxx.edu
> Hi all,
> DC-DC converter.
> DC-DC converter?
> Regards,
> Oleg
> Nabble.com.
View this message in context: http://www.nabble.com/TODD-PC-45-power-converter-charger-tp16236939p16240635.html
Old 03-23-2008, 05:15 PM
That's the key, don't have it connected to the batteries while charging or
equalizing. My pack is 180 vdc and when the pack is charging, I plan to have
a relay that will disconnect my Todd PC-40 (pics at
http://www.ironandwood.org/Todd40.htm)
I have a note in my EV/Charger director that specs on the PC40 say the input
can be from 150 to 190 vdc. There is also a PDF Todd PC30 schematic made by
Lee Hart 5/5/99 that I can put up if anybody wants it and Lee doesn't mind.
Rush
Tucson, AZ
2000 Insight, 66.7lmpg, #4965
www.ironandwood.org
www.Airphibian.com
www.TEVA2.com
Old 03-23-2008, 06:17 PM
Ah, now I recall.. The "b" models are the new ones. They have an
internal voltage doubler that converts the 120AC into 240AC. They might
work on +300 VDC conversions if you bypass the doubler, though I don't
recall hearing of anyone who has done so.
I don't think they'll work on 120VDC, even if you bypass the doubler.
> Both of mine are the red cases. I have a PC30d that works fine on my 120V
> DC system and I also have a (red) PC40b that does not. It lights up the
> red
> (fault)led when I tried it on DC. It works fine on 120V AC even after
> trying it.
> HTH
> Jim
> www.evalbum.com/804
> www.evalbum.com/425
> <I want this device as DC-DC converter - somewhere in Internet I saw the
> info
> converter.
> DC-DC converter?
> Regards,
> Oleg
> mail2web.com =96 Enhanced email for the mobile individual based on
> Microsoft=AE
> Exchange - http://link.mail2web.com/Personal/EnhancedEmail
Old 03-23-2008, 06:45 PM
Lee Hart mailed me a copy of that schematic, and gave
me permission to put it on line here:
http://www.ciciora.com/EV/pc30.pdf
As an aside, someone gave me (2) Power Source PC 75
battery chargers that look very similar to the one
referenced in the ebay add. One was good, and one was
bad so of course I took apart the bad one. Ask Derek
Barger about when I said "Of course the caps are
discharged; let me show you!" and I accidently shorted
the cap leads to the case... Anyway, when I went to
the garage to get the open one and describe it, I
ended up locking myself out. Which normally wouldn't
be so bad, but the rest of my family is in CT, which
is where I would be if it wasn't for the flu I came
down with hours before my flight. So I end up getting
stuck in the dog door (don't laugh, while I could
loose some weight, I have a small dog!). I must have
looked pretty silly 'cause I was still in my pajamas
(this flu has really got me down). Anyway, on my 75
amp versions, first the power goes through some
standard looking line filter, then a beefy looking
bridge rectifier (explaining the 0.7 PF rating on the
cover, along with the 100V-130V AC 30 Hz- 80Hz,
1040W). After the rectifier it's daisy chained to 5
identical switching power supply modules, with a 560
uF 200V input cap and a 25V output cap. There are
also two solinoid inductors on the two output leads.
Hope that helps a little...
- Steven Ciciora
__________________________________________________ __________________________________
Be a better friend, newshound, and
know-it-all with Yahoo! Mobile. Try it now. http://mobile.yahoo.com/;_ylt=Ahu06i62sR8HDtDypao8Wcj9tAcJ
Old 03-23-2008, 07:16 PM
----- Original Message -----
Sent: Sunday, March 23, 2008 7:39 PM
Subject: Re: [EVDL] TODD PC-45 power converter/charger
Hi Steve;
WHERE in Corrupticut? When ya feel better, ya gotta come up, stop by!
Hey, be glad ya got something BIGGER than a 10 lb cat<g>! Hope you DID get
through , and got back in the damn house before ya froze you a** off! Last
time I did that I just busted out a pain in the garage door and got back in,
dignity intact. Had gotten quite proficient at fixing them, with kids that
played B' Ball in the empty garage, years ago! Only 25 miles from New Haven
as the Rabbit flies, it IS Easter.
Seeya?
Bob, already here. BTW the Flu sucks, you feel crappy forEVer, seems
like!
So I end up getting
> - Steven Ciciora
