Bill would you advocate a bottom balance with by drawing each cell individu=
ally down to 0 Volts? =
________________________________
To: Electric Vehicle Discussion List <xxx@xxx.xxx.edu> =
Sent: Saturday, June 30, 2012 11:26 AM
Subject: [EVDL] Zero voltage =3D Zero damage on LiFePO4 (was: A123 ALM 12V7=
Batteries now charging)
[top]
Look in the archives of the EVDL. Folks on this list have done the
experiment on other brands. A123Systems has done extensive testing as well.
The result, discharging LiFePO4 to zero volts and leaving the cell =
there for many days actually reduces the internal resistance and has =
no detrimental effect whatsoever. True fact, even though it is =
completely counter-intuitive.
Bill D.
> > I also should emphasize that the cells themselves really are not
> > damaged by discharging to zero volts.
>Do you have any test data on this? I would like to know what effect on
>capacity, cycle life, etc. going to 0 volts will have.
URL: http://lists.sjsu.edu/mailman/private/ev/attachments/20120701/25a0ae52=
/attachment.html =
