Reviving AGM batts - DIY Electric Car Forums
Old 08-12-2008, 01:12 PM
grose grose is offline
grose is on a distinguished road
Default Reviving AGM batts
I have two 12V, 110AH AGM batteries that have lost a substantial portion of their capacity. Is there any way to revive these or should I get new ones?
Old 08-12-2008, 01:52 PM
TheSGC TheSGC is offline
Default Re: Reviving AGM batts
What are you using for a charger and how old are the batteries?
2001 Civic EX EV
Old 08-12-2008, 02:05 PM
Charger is a Schumacher 12V 6A smart charger. The batteries are a year old and have 1600 EV miles on them.
Old 08-12-2008, 11:12 PM
rebenergy rebenergy is offline
rebenergy is on a distinguished road
Hi grose
My advice is just off the cuff and I am leaving for vacation, so I can’t provide any links to support my statements at this time. A Schumacher 12V 6A smart charger may not provide enough current to equalize the batteries. (Equalizing is the causing of bubbles to move by plates mixing electrolyte and chafing the lead sulfate crystals off the plates). If the batteries are sulfated a few good equalizing charges may help. You could then follow this process by topping off the electrolyte by adding standard battery acid, NOT distilled water. This will not damage old batteries, but gives them a second wind. If you have the time you could buy a high frequency desulfatetor. I have heard good reviews, but have not yet used one my self. I do not believe in using cleiagents (sorry bad spelling) like EDTA. They encapsulate the lead-sulfate crystal sloughing so much sludge to the bottom of the plates and sorting them out.
Here is a clip of an old advertisement --
PulseTech® battery maintenance systems clean the
working parts of your battery...and here’s the
VISIBLE PROOF!
These are crystallized sulfur
molecules on a typical lead-acid
battery plate. These “sulfates”
reduce your battery’s capacity,
shorten its lifetime, and interfere
with energy efficiency... bad news for
your battery.
Here’s the same plate 18 days later,
after installing a PulseTech® battery
maintenance system. The plates are
clean. This battery’s storage capacity
increased 250%, without the use of
costly equalization charging... good
news for your bottom line.
Extend the Life of your Batteries!
Accept no substitutes; the cost
effective PowerPulse® units
are patented, approved by the
U.S. Military, and have a tenyear
limited warranty.
n Free delivery to 50 States. n VISA/MasterCard OK!
n Bulk/Dealer inquiries invited.
Old 08-12-2008, 11:41 PM
ww321q's Avatar
ww321q ww321q is offline
ww321q is on a distinguished road
Send a message via Yahoo to ww321q
Cool Re: Reviving AGM batts
I have had some luck desulfating regular lead acid and gel cells . How come just 2 batteries ? I'm sure your string is longer ? They could be dried out from high discharge or to high voltage when charging . there are desulfaters that you can build to . The Schumacher chargers I have , have one built in . I also have another I bought .
[top]BLS-12/24B
http://www.batterylifesaver.com/products/products.htm
hope this helps J.W.
Old 08-13-2008, 09:15 AM
TX_Dj's Avatar
TX_Dj TX_Dj is offline
SPAM Cop
I don't see how this is a possible suggestion with sealed AGM batteries.
cheers,
dj
"I'm No Expert!(TM)"
Old 08-13-2008, 10:02 AM
[top]BLS-12/24B
Just two batteries are showing this weakness in the string. The others load test better. How successful are these desulfaters? Are there any verified results that they work? (other than anecdotal)
Old 08-13-2008, 10:12 AM
adric22 adric22 is offline
adric22 is on a distinguished road
You took the words right out of my mouth. I was about to mention the same thing. Not only can you not add acid to an AGM, but I don't believe you want any bubbles forming in there. Bubbles are very bad for AGMs.
David Murray
Electric 1993 Eagle Talon
http://galaxy22.dyndns.org/ev-talon
Old 08-13-2008, 12:17 PM
judebert's Avatar
judebert judebert is offline
judebert is on a distinguished road
On the EVDL, none other than Lee Hart himself suggests that some AGMs can be saved by drilling a small hole (7/64", I believe), adding the fluid, and sealing the hole with silicon and a #7 screw.
Old 08-13-2008, 12:40 PM
TX_Dj's Avatar
SPAM Cop
It certainly doesn't surprise me that Lee would do something like that. And if he has, and was successful, I would trust his data on the subject... question is, does anyone have a link to his findings?
cheers,
dj
