Old 08-18-2012, 01:00 AM
RIPPERTON's Avatar
RIPPERTON RIPPERTON is offline
RIPPERTON is on a distinguished road
Default Re: RIPPERTON Electric track bike
It grows and grows......
no where near finished yet but starting to shape up
My YouTube Channel http://www.youtube.com/user/RIPPERTON?feature=mhee#p/u
Old 08-18-2012, 08:16 PM
ryry ryry is offline
ryry is on a distinguished road
Very good rip, im sure that the extra motor will give you a much bigger buffer with pushing things to there limit, after all theoretically you have twice as much area for power and heat.
itll be good to see what results your going to get once you start with the two on the same controller especially .
Also i may add, Very Very nice job on all your work with the cnc, nothing looks out of place.
Old 08-18-2012, 09:45 PM
jonescg's Avatar
jonescg jonescg is offline
jonescg is on a distinguished road
Looks like it's air cooled from this angle
Old 08-19-2012, 01:56 AM
RIPPERTON's Avatar
>Meh
Im snooping around for some thin carbon fibre sheet to cover the square openings but this is where I am now, have all the lightened spacers in place.
Next is the shafts.
I just decided to turn the motor around so the cables poke out backwards.
Old 08-19-2012, 07:39 AM
hey rip.
Have you thought about maybe doing a bit of a star delta setup on the two motors. it could act as a bit of a second gear, or more high and low gear.
Old 08-19-2012, 11:07 AM
Zak650 Zak650 is offline
Dan,
Why not cover the openings with fiberglass window screen material possibly with small square hardware cloth on the outside of that? It's got airflow directly through the motors that way.
Old 08-19-2012, 08:06 PM
RIPPERTON's Avatar
Originally Posted by ryry View Post
hey rip.
Not with these motors, would require rewinding.
The larger stators Im having quoted in China could be series parallel.
Old 08-19-2012, 08:10 PM
RIPPERTON's Avatar
Originally Posted by Zak650 View Post
Dan,
I just bought 3 sheets of 0.75mm carbon fibre on Ebay, would look much better than fly screen. coming from Germany $96 ouch
Im normally not too fussed about appearances but after seeing the way the frames came out of the cnc its turned into a "work of art" thing.
hope it actually runs
Old 08-19-2012, 09:11 PM
evmotorcycle evmotorcycle is offline
evmotorcycle is on a distinguished road
This looks like a piece from the freakin' Mars rover! Only thing missing is a laser for shootin' them rocks!
AWESOME!
Old 08-21-2012, 07:47 PM
RIPPERTON's Avatar
AWESOME!
You mean shootin them Catavolts !!.
Got both shafts turned and stators drilled.
Still a long way to go.
