11-19-2008, 09:16 AM
S-10 with a Kelly 650 AMP
I had an S-10 with a Curtis 500 amp. Did 77MPH. I sold it,  , and bought a better S-10 and have installed a Kelly 650 AMP controller. Problem is, I'm only getting 45mph. Dont have amp meter yet, so I'm not sure what its putting out, but with the old truck, I had a Kelly 500 AMP and it only reached a maximum of 300 amps initially and quickly went down to a maximum of 170 amps after warmed up. It only did 40 MPH and creeps up hills.
Why do I get better acceleration/top speed with a Curtis 500 than with a Kelly 650?
11-19-2008, 09:51 AM
Re: S-10 with a Kelly 650 AMP
What voltage are you running? We will know more with an amp meter too.
I'm interested in what you find out. Is the controller the Kelly A or B?
11-19-2008, 10:42 AM
It sounds like they don't rate their controllers the way the rest of the controllers do. Amp ratings are based on a Temperature rating on the FET's inside, as well as a duration. Sounds like they're running hot, and not for very long... which limits their output current. I haven't heard one person say they actually live up to those current ratings. A couple of EV parts distributors say they're more like 1/2-1/3 the rating, and they they've NEVER reached their max.
Measured is one thing, but going off the FET datasheet for max amps unrealistic. I seriously doubt they've actually measured their absolute max current output.
Are you sure your batteries are not sagging? That can limit current too.
11-19-2008, 01:11 PM
I hate to be the bearer of bad news, but I'm sorry to say you are not the first one to see a drop in performance after switching from a curtis to a to a kelly controller that was supposed to have more power. You could try and contact kelly and see if they can help you because there are some on the forum here that are satisfied with their kelly controllers.
11-19-2008, 04:49 PM
SPAM Cop
Which amps?
The controller rating is typically the output rating, i.e. motor amps, not pack amps. If your ammeter was on the pack side of things, 300A is probably about right, as it can pull less amps at higher volts on the input to make higher amps lower volts on the output.
cheers,
dj
"I'm No Expert!(TM)"
11-19-2008, 05:48 PM
Originally Posted by TX_Dj
Which amps?
Ahh, another very good point from TX_Dj!!!
you won't ever see 650A on the battery side, and I honestly don't think they could supply it without sagging/crackling/popping...etc.
11-20-2008, 07:21 AM
What kind of heatsink are you using for the Kelly?
I too have a Kelly, but I have not measured the AMPS coming out. However, I did notice my Kelly getting pretty hot doing short runs and I had heatsink (3/4" aluminum plate) with thermal grease. I then wiped off the thermal grease and used a high AMP thermal pad, and now my controller is pretty much stone cold after a high power run. I am actually worried about frying my motor with the 400 AMP Kelly since my motor gets a lot hotter than anything else.
11-24-2008, 07:27 PM
I have a heat sink I pulled and cut from an industrial drive. Mated it to the Kelly with thermal grease. In the old truck, I had fans blowing through the sink, but with this one, its so cold now, I figure I didn't need a fan.
Doesn't matter, I just got a call my Curtis 1231C is in the mail, and it runs better than a Kelly 650 any day.
11-24-2008, 08:40 PM
I still think that throttle setup is holding you back with the Kelly. On Wednesday I am putting my EV back together and I am going to find my top speed and I am going to try the different controller settings.
11-25-2008, 06:52 AM
I'm not driving my truck around lately, its been snowing, so I guess I'll try the other throttle variations and see what happens. My last truck was wired with one of those variations, and it didn't work at all. The diagram, at the time, showed a block with three wires going into it, and my throttle was a two wire. So I had to e-mail Steven at Kelly to get a good version to wire it up, and he gave me the current version I'm using in this truck. My Curtis will be in by this weekend, so if I can't get anything more out of the Kelly, its gone! Will make a great paperweight, or toy car controller.
