Old 07-07-2012, 10:48 AM
Carroll_1 Carroll_1 is offline
Carroll_1 is on a distinguished road
Default For Sale: 1992 Toyota Tercel Conversion - Needs batteries
1992 Toyota Tercel was converted in 2009 as part of EV-Solutions R&D program. It's fitted with (12) 12V MK Gel batteries which are now at the end of their useful life and will need replaced. The body is fair with some rust over the rear wheels and a wrinkled left front fender. The car is located in NW Illinois.
Asking Price: $5250.00
Details and photo links are:
  • NetGain ImPulse 9 motor
  • EV-Solutions CNC machined trans adapter and motor coupler
  • OEM clutch and 5-speed trans
  • MaxForcer 1000A controller
  • Fiberglass control circuit box
  • (2) SW-200 contactors
  • Anderson disconnects
  • EV-Solutions HDPE plastic and aluminum insulated battery boxes
  • Iota DLS-55 DC-DC converter
  • 12VDC Vacuum brake assist kit with reservoir
  • Electric block heater with 12VDC RV water pump for winter heat
  • Westec Ammeter & Voltmeter
  • Blue Wave EV gauge system w/7" dash mounted LCD monitor
  • New brakes all 4 wheels at time of conversion
  • New heavy duty rear springs at time of conversion
  • Less than 1500 miles on conversion
More photos at: http://www.photobucket.com/evs-tercel
Old 08-12-2012, 04:05 PM
Default Re: For Sale: 1992 Toyota Tercel Conversion - Needs batteries
Anyone interested in parts if we part it out? The controller won't be available as I'll send it back to the developer, but is anyone interested in the remaining components?
Old 08-12-2012, 04:42 PM
If anyone's interested I've also got one set of new 2nd gen S10 (94-04) rear battery box frames and boxes left from inventory. The steel frames are powder coated gray, the 14 ga steel boxes are powder coated black, and the boxes are lined with 1/2" thick black expanded polypropylene foam insulation/cushioning. Here's pics of a typical installation. The two side boxes (behind cab) hold four GC2 size batteries, the rear box holds eight batteries.
This is the last of our EVS hard components. All of the under hood frames, boxes, and parts and tilt-bed parts are gone. Not sure how I ended up with one lone set of rear frames; we built these six sets at a time, I must have mis-counted when cutting stock
Only other items left are the thirty adapter/coupler digitized and solid modeled designs I have in Solidworks and I'll keep them as a package.
Craig
Old 08-15-2012, 07:56 AM
hbthink hbthink is offline
hbthink is on a distinguished road
How much for the Solidworks files? I have Solidworks and need to design an adapter plate and mount for a 93 Volvo 850 to Netgain Warp 9 motor. Do you have files that would work for this? How much do you want for them or the whole lot?
Steve
Old 08-15-2012, 09:54 PM
Steve
Sent PM reply
