Old 04-12-2010, 09:40 AM
toddshotrods's Avatar
toddshotrods toddshotrods is online now
Default For Sale: (2) 1.625" x 25T Splined Hubs - $45 each
I have two extra hubs from building the direct drive adapters for the 11" GE SepEx motors, or anything else with a 1.625" x 25T splined output shaft. We didn't realize that these hubs (from a different supplier) are a bit smaller with a different pattern than we have programmed. They've been liberated from the PTO discs, and the rivet holes bored out to accept 7/16" bolts and/or pins. Perfect (slip) fit on the big GE output shaft.
I can help with an adapter if you need it, or you can just purchase the hubs and do your own thing.
Old 05-12-2010, 08:40 AM
Default Re: For Sale: (2) 1.625" x 25T Splined Hubs - $45 each
If anyone has an 11" or 13" GE motor and has already purchased a PTO disc from SSB Tractors to match the splined output shaft, I have two adapters already machined and ready to be assembled with Spicer flange yokes. There are at least two different PTO disc hubs. These adapters are machined for the 10-bolt hub. It has a centering ring (that the actual PTO disc fits on) of 2.549", and overall diameter of 3.872", and the ten bolts are on a 3.25" bolt circle.
The adapters can be purchased as is for you to finish, or we can finish them for you. The flange yokes have to be machined to fit in the recess, and the recess in the adapter machined a little bit to receive the hubs.
I also have one more hub (the one on the right), already removed from a PTO disc.
PM me if you're interested...
