Originally Posted by Nuts&Volts
No, but it appears that the maximum switching frequency is 15kHz. I believe if you use this and the pole pair count of the motor you can determine the maximum RPM possible by the controller. I think is is RPM=(freq*60)/(# of pole pairs)
I can ask him explicitly if you would like or we can just until the manual is released.
Do ask if you don't mind.
It heavily affects gearing choices.
I'd also prefer AC induction, less chance of demagnetizing the permanent magnets.
Also we'd need sinusoidal. Trapezoidal probably won't cut it.
Originally Posted by ruckus
any interest?
Obviously :P
Then again I'm not going to be the first adopter. If it works, it works.
