DIY Electric Car Forums > General Forum > EV News
Old 06-21-2012, 08:21 AM
News Bot News Bot is offline
News Bot
News Bot is on a distinguished road
Default Shift Detected in Obama Stance on Fuel Cells?
Heather Zichal, President Obama's top aide on energy and climate change, called Hydrogen cells 'an opportunity' for improving fuel economy.
More...
Old 06-21-2012, 09:54 AM
Default Re: Shift Detected in Obama Stance on Fuel Cells?
Originally Posted by News Bot View Post
Heather Zichal, President Obama's top aide on energy and climate change, called hydrogen cells 'an opportunity' for improving fuel economy.
the real link.
http://www.businessweek.com/news/201...ng-plug-ins#p1
Men and their Toys.
Old 06-21-2012, 02:33 PM
jeremyjs jeremyjs is offline
jeremyjs is on a distinguished road
unless they're talking about solid oxide Fuel Cells that can run on hydrocarbon fuel it's a huge waste of time and a huge step backward. Dealing with Hydrogen is just silly and incredibly inefficient.
Old 06-21-2012, 02:40 PM
sounds like someone connected with fossil fuels.
thankfully not all agree with you.
http://automobiles.honda.com/fcx-clarity/
they are presently using them in Calif.
Men and their Toys.
Old 06-21-2012, 03:09 PM
If I were in the fossil fuel industry I'd probably be for it. The cheapest way to make the stuff is with natural gas. If you're going to use electricity to split water you're in the range of efficiency of an ICEin the power you put to the ground. By the time you split the water, compress it to a ridiculous pressure, then run it through a fuel cell you'll be lucky to get 30% efficiency to the ground doing work. Not to mention the storage and transportation issues of needing to use a 10,000 psi tank to get a useful amount of range and having to store that bomb inside of your car. No thanks.
I'd much rather stick the electricity directly into the car and avoid the whole idiotic process. Oh and get 2-3 times the efficiency out of the electricity that's used.
The Hydrogen economy is a fools errand if there are batteries good and cheap enough. They already are and will only get better.
Old 06-22-2012, 01:21 AM
Duncan Duncan is offline
Thumbs up Re: Shift Detected in Obama Stance on Fuel Cells?
Now there is a smart guy!
The whole Fuel Cells - Hydrogen nonsense is just a scam to keep people having to use "Gas Stations"
Old 06-22-2012, 01:59 AM
So how much natual Gas can you carry with out it being compress (CNG). Where do you get the energy to compress it to 3,000 psi? By your logic all the CNG buses are Bombs.
Now for those that don't know about Hydro, thermal and solar produced electricity I would expect that logic.
The hydrogen economy is a fools errand if there are batteries good and cheap enough. They already are and will only get better.
Where do you get the Electric power to recharge you EV?
Remember we are not talking about efficiency at the detriment of the environment.
Men and their Toys.
Old 06-22-2012, 05:28 AM
Jason Lattimer's Avatar
Jason Lattimer Jason Lattimer is offline
Jason Lattimer is on a distinguished road
Actually, even the highest efficiency industrial electrolysis is only 15% efficient. And having looked into cng, you must be federally certified to do a conversion and the fuel tank has an expiration date.
Check out my new website for velomobiles.
www.velomobilenews.com
And now, more controversial subjects.
http://sustainablepolitical.blogspot.com/
Old 06-22-2012, 08:12 AM
I'm not advocating CNG buses, cars, etc. That said it is a better solution than Hydrogen. CNG is stored at much lower pressures and doesn't leak straight through steel and destroying it's crystalline structure, making it brittle, on the way.
I'd rather use the electricity directly rather than throwing 3/4 or more away trying to make Hydrogen work.
I'd rather save the natural gas for heating homes and running turbine peaking plants or better yet a high efficiency combined cycle power plant.
The thing Hydrogen is best at is making you throw most of your energy content away trying to get it into a useable form for running through an expensive fuel cell.
Hydrogen is best left to using it where it's absolutely necessary for industrial applications.
Old 06-22-2012, 08:34 AM
PhantomPholly's Avatar
I know some folks just love the idea of Hydrogen, and if and when the day ever comes that we find a cheap & clean way to make it I might join them. However, as noted in the article it costs $500k just to put in a filling center. Even liquified, you need a lot more storage volume to get the same range as an ICE vehicle using petrol - and even more volume and weight to support the cryogenic containment vessel. In a fuel cell, yes, you might get better mileage than in an ICE, but then you're talking Platinum in the fuel cell, etc. etc. etc.
Assuming for arguments' sake that battery and Hydrogen technologies continue to advance at their averaged 50 year pace, batteries will win on simplicity, safety, cost, and capability.
