Old 02-20-2010, 06:59 PM
frodus's Avatar
frodus frodus is offline
frodus is on a distinguished road
Default Re: Single Cell LiFePO4 charger?
Originally Posted by dtbaker View Post
sounds interesting.... more specs available? i.e. how close is that 3.7v?
I am asking to get a feel for how much babysitting it would require. Lets say I have a low cell, and hook this baby up... could I walk away ad let it coast it's way up to 3.70 and hang there, or do I have to watch and disconnect after x amount of time to prevent over-voltage?
Its a 2-part system. One is a AC-DC converter that puts out 48V and 300W. The second part is a Vicor DC-DC 48V to 3.7V converter. It will put out high current as its loaded and as it gets closer to 3.7V current slows. It will hold at 3.7V.
Travis Gintz
www.evfr.net
Old 02-20-2010, 07:07 PM
dtbaker's Avatar
dtbaker dtbaker is offline
hhmmm, and how would this compare in price to a power supply that can be had for around $150 that has settable 0-30v/0-10amps ?
or conversely, a cheapo resistor to bleed some energy out of the high cells and bring everything back up with the pack charger?
Dan
http://www.envirokarma.org/ev
Old 02-20-2010, 08:14 PM
gdirwin gdirwin is offline
gdirwin is on a distinguished road
Originally Posted by Voltswagen View Post
I plan on buying this Mastech once my Lithiums arrive.
http://www.mastechpowersupply.com/dc...n/prod_70.html
They also have a 15V/20Amp model - 1/2 the voltage (but still good for 12V batteries) but double the current...
I was confused how these things switch from constant current to constant voltage - there is a dial for current and for voltage... It auto-switches from one to the other - you would first start with an open circuit, and set the voltage to your max charge voltage (say 4V). Then you turn the current down, and connect it to the battery. Then you crank up the current - it will be in constant current mode until the voltage nears 4 V, then it will switch to constant voltage mode (and display the measured current).
In other words, if it is in current mode, then the current displayed is on the limit, and the voltage shown is the measured voltage (the limit is higher than this). If it is in voltage mode, then the voltage displayed is on the limit/set-point, and the current shown is the measured current (which should be decaying). Sounds perfect!
Make sure to get the EX models - they have OV (over-voltage) protection, and will not self-destruct if the voltage ever gets higher than the set-point (ie it cannot tolerate reverse current). Apparently this was a big problem in the E and D models - Mastech responded to customer complaints, suggested diode front-ends to help, but ultimately fixed it with the EX models.
The D models (linear power supply, not switching) have way less ripple, tighter tolerances etc... (and are much heavier and about $10 more) but also are not good for battery charging as they do not tolerate reverse current (ie no OV protection).
Rob (RKM) and I each got a 15V/20A EX model - will let you know how they work when they arrive (probably Rob first, as my TS cells are literally on a "slow boat from China").
Old 02-20-2010, 11:53 PM
frodus's Avatar
Less than half the cost. With a few resistors you can set it to a lower voltage. Its by no means pretty, but it does its job well, many have used these same modules.
Travis Gintz
www.evfr.net
Old 02-21-2010, 10:15 PM
frodus's Avatar
Well, I put a few of them together, here are more details:
http://www.diyelectriccar.com/forums...749#post167749
Travis Gintz
www.evfr.net
Old 02-24-2010, 01:14 PM
O'Zeeke's Avatar
O'Zeeke O'Zeeke is offline
O'Zeeke is on a distinguished road
hi gd, are your ts cells from ev components? I am waiting on that boat too and haven't heard anything recently.
Zero point Zero
http://www.diyelectriccar.com/garage/cars/47
Old 02-24-2010, 03:32 PM
Voltswagen Voltswagen is offline
Voltswagen is on a distinguished road
I emailed EvComponents yesterday about the Feb. Delivery for batts ordered before Dec. 15th
They said the container is in Seattle going thru customs. They expect to pick them up this week and begin delivery next week.
DISCLAIMER: What you read may not necessarily be what I wrote!
Old 02-24-2010, 05:59 PM
My TS cells are from EVComponents, but were shipped directly from China to Canada - they are supposed to arrive in Vancouver on Feb 25, but then (wrongly) are to be put on a truck to Toronto - well Toronto is 2,200 kM past Winnipeg, so an extra 4,400 round trip by the time they come back to me... Dave at EVComponents is trying to contact TS in China to fix this, but it is Chinese new year, so no-one is available... Hopefully to be fixed in the next day or so...
Old 02-24-2010, 06:07 PM
O'Zeeke's Avatar
Thanks Voltswagen
Slow boat is bad enough, you dont need a slow truck too. Hope Dave gets it fixed.
Zero point Zero
Old 02-24-2010, 08:33 PM
PTCruisin PTCruisin is offline
PTCruisin is on a distinguished road
Hi Travis,
Do you have any of those left? I'd be interested in purchasing one.
-Ralph
