Old 06-27-2012, 12:47 AM
Fewski Fewski is offline
Fewski is on a distinguished road
Default What size potentiometer?
I'm not sure how the sizes for potentiometers are calculated.. so need some help here.
I'm building a controller to run a 500 Watt 36 Volt motor 18.3 Amps. I have no idea what size potentiometer I need to do this. Any help on calculations?
Old 06-27-2012, 04:53 AM
Default Re: What size potentiometer?
The pot is used as a control input signal from the throttle pedal or twist grip. It normally runs 0 to 5 volts or maybe 10V max. Typically it is a 5 or 10 kΩ pot.
Old 06-27-2012, 11:30 AM
Thanks for the reply. What about the amount of Ohm's? I've seen them from 50k to over 1m.
Old 06-27-2012, 11:34 AM
frodus's Avatar
frodus frodus is offline
He already told you.
If you're building this and are asking how many OHM's, I'm a bit worried. You can choose how many ohms you want to use. How the controller uses the signal into the microcontroller that is signalling the FET's is up to you and your design.
Normally people have 5V attached to one end of the pot, signal ground to the other end, and the wiper goes to the A-D converter (with some filtering for noise). That way the A-D converter sees a voltage between 0 and 5V. How many ohms you use is completely up to you, but normally we see 5-10kohm potentiometers.
Travis Gintz
Electro Motive Force, LLC.
EV Consulting and parts Sales
Brammo Empulse R #24
