http://ecomodder.com/forum/attachmen...8&d=1202049916
http://ecomodder.com/forum/showthrea...cap-583-4.html
I had a nice point by point long post worked up but then I got a blasted spyware attack and crashed, everythings reinstalled now, bleh.
Anyway I would strongly consider making a lightweight aero flatbed/belly pan with wheel covers, Then repeat what bondo did above making a tiltable angled cover, I would keep the line of the cover just below the rear window. Since this would be a true boattail you could easily gain 20% more range just from the aero improvement, likely closer to 50% depending on your speed.
I would also attach the panels securely to that cover so although possible to remove eventually it would be big boxy, bulky and downright heavy making it almost impossible to steal.
Having a lightweight bed and cover on the back would allow the batteries to have a nice place to be put out of the weather and accessible. Also they would give you a bit more traction.
As for having separate MPPT systems to charge that is PERFECTLY fine so long as they are equally sized. You will have to do more maintenance on the batteries to keep equalized but you should do that anyway. Also remember panels run separately usually put out more power in total then when run in series but they also put it out unevenly.
Next don't bother building panels from solar cells, If I could still find the individual cells for $0.50 a watt I personally would build a custom panel but remember homebuilt have some major issues
1. Cost of ownership, solar cells die rapidly exposed to any form of moisture and the RTV like compounds to seal correctly are very expensive.
2. Complexity, there are literally thousands of solder joints to make in your project, meaning thousands of chances to get a cold one lighting fire
3. Lifespan as I mentioned most homemade panels, even those done correctly are indoor only and die within about 5 years outside.
So just find panels that will both fit within the area you have and also meet the voltage requirements needed when added together.
Solar panels have two voltages, one is the lower rated voltage that provides maximum amperage output the higher voltage listed is the open circuit voltage.
Generally the minimum voltage panel you need must have ideal amperage output at around your floating voltage, however if you don't want the panels to overcharge you can build an unregulated array that only goes up to the max voltage you want the batteries to see but then they are much less efficient.
I had a much better writeup earlier, ah well.
Cheers
Ryan
