Old 07-09-2012, 10:33 PM
PeterH PeterH is offline
PeterH is on a distinguished road
Default Soliton Jr. Switching Frequency?
Hi there,
Been driving my EV for only a few days. I believe the Soliton is generating a high pitch tone. It is currently set for 'performance' meaning it is switching at 14 KHz. The alternate setting will cause it to switch at (I think) 8 KHz.
Just wondering what difference it makes to the equipment if I switch to the lower frequency switching. Does it make the Soliton run warmer? Will motor control be any different? I have absolutely excellent control over the motor at the moment, so I'm hoping changing switching frequency won't cause a change in how well I can control the motor.
My Kostov motor is making its own whining sound which is much louder than I expected it to be. I'm hoping it is just a matter of the brushes still breaking in.
I have the Soliton settings dialed down for now, just to ensure I don't draw too much current, too quickly. But even at these settings, I think it drives better than the original, unconverted vehicle!
Thanks,
Pete
Old 07-10-2012, 06:11 AM
Yabert's Avatar
Yabert Yabert is offline
Default Re: Soliton Jr. Switching Frequency?
Hi Peter
Performance setting = 8KHz
Quiet setting = 14 KHz
The difference of control over the motor will be imperceptible, but more switching = more lost, so the soliton will run warmer at 14 KHz.
Plug your laptop and watch temperature if you don't running water cooling on the Jr.
My Smart Fortwo high power!
Old 07-10-2012, 07:43 AM
OK, thanks. I'm not yet running a cooling system for the solution so I'll learn to live with the sound... at least till I have a cooling system in place. Hopefully that will be next week sometime.
Pete
Old 07-10-2012, 08:30 AM
Yukon_Shane Yukon_Shane is offline
Yukon_Shane is on a distinguished road
Pete
Let us know how well switching to quiet mode works for you. I switched to quiet mode after a couple of days of driving which definately improved the sound but I can still hear an audible "singing" when I push on the throttle. I'm thinking in my application it's related to the fact that my motor is solid mounted to the frame (mistake) but maybe it's also related to the amount of sound insulation in the geo trackers.
Old 07-10-2012, 01:09 PM
azdeltawye's Avatar
azdeltawye azdeltawye is offline
azdeltawye is on a distinguished road
My Kostov motor is making its own whining sound which is much louder than I expected it to be. ...
My Kostov motor sings as well. I have to run the controller in ‘Quiet mode’. Otherwise it will turn heads at 500 feet…
Darren Sims
Registered PE - Electrical
http://www.diyelectriccar.com/garage/cars/253
Old 07-10-2012, 05:39 PM
piotrsko piotrsko is offline
mine doesn't sing in either mode. I hear louder tranny whine especially in 4 low.
Old 07-11-2012, 08:41 AM
I'm fairly sure my sounds are coming from the motor and the Soliton. If I just coast for a while and let the motor spin down, everything is nice and quiet... almost too quiet because I hear every little rock hitting the the new paint!
Since I'm the only driver so far, I don't know how far away you can hear my EV but I need to run a test with my wife listening. She can hear a worm fart at 200 yards... I can't even mutter under my breath and get away with it... so she will gladly tell me how much noise I'm making!
Parts for the cooling system should be here Friday!
Pete
Old 07-11-2012, 10:00 AM
m38mike m38mike is offline
m38mike is on a distinguished road
I've been running my Soliton Jr for many months now on "performance" mode (8 mh) with the liquid cooling. I get a slight high pitched whine out of it when I'm accelerating, but I don't notice it when I'm cruising at speed. My WarP11 is silent at all speeds, at least that's how it sounds to me inside Electro-Willys. The tires and transmission and wind noises are the only sounds I'm picking up.
