Old 06-16-2012, 12:43 AM
Genius Pooh Genius Pooh is offline
Banned
Genius Pooh is an unknown quantity at this point
Send a message via MSN to Genius Pooh
Default Is There cheap BLDC Controler?
Hi I try to use remy motor It's amazing one...
Motor is just 5000$ but power is 200hp and maximum 450 hp...
Wow... It's amazing but problem is controller..
VAXO recommend me reinhart controller It's too expensive about 10000$
and below motor's power (motor is 600amp and 700vdc max but controller is just 350amp peak..)
Can you recommend me better one or cheapper one?
I know It's not that expensive price but... I try to find optimized one...
And what is used at F-150 truck??
Thank you..
Old 06-16-2012, 05:12 AM
Ivansgarage's Avatar
Ivansgarage Ivansgarage is offline
Ivansgarage is on a distinguished road
Default Re: Is There cheap BLDC Controler?
For a big truck???
http://topekaelectricmotor.com/files...Curtis-123.jpg
check out this full size pickup. Went for a ride in it. Runs like it has a v8 in it..
http://topekaelectricmotor.com/elect...les/ac-project
Ivan's Garage 1999 Electric Sonoma Pickup
http://ivanbennett.com/forum
This is just a test! Hand wound motors.
Old 06-16-2012, 03:09 PM
what do you consider a range for Cheap.
the money is in the Peak Voltage Rating and Power Stage.700 VDC is normal to keep the current below 330 AMP.
you looking at 335.6 KW @ 400HP
245KW @700 Volts 350 amps
so you need to define you parameters.
Thank you..
Simenond is about $4,000 for 100KW
Men and their Toys.
Old 06-16-2012, 03:50 PM
marc02228 marc02228 is online now
marc02228 is on a distinguished road
What is this Simenond controller? Where do I find it?
Old 06-16-2012, 05:27 PM
That Scott drive think is 150kw peak, and if you want to go cheaper, there are the Kelly controllers.
Old 06-16-2012, 07:06 PM
sorry about that, Senior moment before nap.
Siemens if you can find a surplus one.
http://www.metricmind.com/ac_honda/motor.htm
bottom of the page.
Men and their Toys.
Old 06-16-2012, 08:16 PM
Arlo Arlo is offline
Arlo is on a distinguished road
Good luck. But the nice thing is with electronics the price will come down!
Worlds fastest electric bmx? http://www.youtube.com/watch?v=HSh8uGcFpJs
Yamaha E-YSR with 15kw DIY BLDC controller!
http://www.youtube.com/watch?v=91pGd...6Y37xYFFPRdPhw
Old 06-18-2012, 04:04 PM
bottom of the page.
That was in 1998! 14 years ago!
Old 06-18-2012, 11:58 PM
There just isn't a lot automotive capable BLDC and AC out there, right now DC reigns supreme for the HP&TQ/$ ratio...maybe one day BLDC will be cheap enough...
Old 06-19-2012, 01:24 AM
yes, it was the prototype I built my Controller from, with some added info from the Allison EP50.
then I added the 56F803 as the core of the controller using their Application note.
AS I SAID if you can find surplus one.
Men and their Toys.
