Old 07-05-2012, 03:59 PM
PhantomPholly's Avatar
Default Re: Is there multi fuel diesel engine?
Most diesel engines will successfully burn butane, propane, or natural gas at the right mixture levels. For a little while, that is. Alcohol might even work. Problems come in if the fuel burns too much hotter than diesel or when the flash point is too much lower - then the engine will knock severely.
Old 07-05-2012, 06:33 PM
PStechPaul's Avatar
Lightbulb Re: Is there multi fuel diesel engine?
The old Sattley engine I found had a water tank, and I think its purpose was to slow the combustion of "hot" fuels to reduce knocking and get more usable power. There have been some of these on the market from time to time. I think it is based on some sound principles and is not the same as the claims of running an engine on water. It may also have a "steam engine" effect, when the water vaporizes.
Old 07-05-2012, 10:45 PM
NintendoKD NintendoKD is offline
NintendoKD has a little shameless behaviour in the past
Send a message via AIM to NintendoKD Send a message via Skype™ to NintendoKD
look at the cucv military vehicle deuce and a half or M35 multifuel motor, can run her on gasoline provided that you dump a gallon of motor oil in the tank "used at that"
see: LDT 465 by hercules, white motor company or continental motor company, it is a 478ci 7.8L turbo inline six, and will run on damn near anything, there are rumors of guys running low on fuel and pissing in the tank to make it back to base, but I have been in that situation and it isn't a rumor anymore. they really will run on darn near anything, I can't remember the name of the book but there was a guy at the turn of the century that wrote a book, published around 1900 that did experiments and documented what could and could-not be used in various ICE's, to include gasses, steam, compressed air, among other things.
A lot of money first. A good light weight vehicle. 9" motor, Soliton1, Synkromotive controller, Warp Drive Controller, Zilla Controller. A large pack of lithium batteries. 45 kWH at least. A good charger and lots of money. Oh, and more money. It will be expensive. You won't be able to do that with Lead Acid batteries. PETE
Most of the other stuff is minor compared to the car, motor, controller and battery pack.
Old 07-06-2012, 06:41 PM
Genius Pooh Genius Pooh is offline
Banned
Genius Pooh is an unknown quantity at this point
Send a message via MSN to Genius Pooh
Originally Posted by PStechPaul View Post
I have looked into various alternative fuel engines. There are also some systems that incorporate both. But here are some interesting sources for steam and multi-fuel diesel engines (and there was even an old Briggs and Stratton lawnmower engine that ran on Kerosene). And there are some videos on youtube showing people who converted a lawn mower to run on steam. Funny to watch somebody bouncing along behind a mower with a water-filled propane tank in a barbeque grill in a cloud of smoke and steam!
http://youtu.be/eeCWLjoJ0FA
http://www.greensteamengine.com/
http://www.mikebrownsolutions.com/mbsteam.htm
http://www.tinypower.com/
http://www.backwoodshome.com/articles/goebel43.html
http://www.tinytechindia.com/steampowerplan.htm
You can get small diesel engines on eBay and elsewhere from Koop:
http://harvestchapelmission.org/page...cooled-diesels
And here is a power source that runs on 50% vegetable oil:
http://harvestchapelmission.org/page...run-50-veg-oil
It's extremly valuable information... Wow you are real genious..
Thank you very much!! I owe you!
