PStechPaul:
You might want to check all your connections and wiring to see if you are dropping too much voltage there, and monitor the battery voltage for sag
How would I test for voltage sag? All I’ve done so far is confirm that the voltage across the pack is the same voltage across the controller when the car is on.
You can check the voltage (or resistance) on the accelerator pot box to see if it is pushing the controller to maximum
I tested the resistance of the potbox with my ohm meter and at 0 acceleration, it read 0 ohms and a full, it was 1. That seemed odd to me. Shouldn't it be the opposite? 0 resistance at full throttle.
Ziggythewiz:
Disconnect the pot leads from the controller and check what values you get when *someone else* presses pedal to full and at 0.
How would I go about doing this? If I disconnected the motor the controller would have no load right? But if I left the motor connected, and did that, the car would move, making it very hard to measure anything
And by values I assume you mean amperage to see how close to 500A it gets.
I have my ammeter/shunt wired on the negative side between the pack and the controller (and a fuse). Would that work for measuring the amps the controller outputs, or would I need to measure the amps between the controller and motor?
Just how sluggish are you?
If I’m stopped on a slight uphill before an intersection it probably takes me 10 sec or so to finally get across and up to speed. That's a rough estimate, but I’m defiantly starting to think something is wrong based on everyone's responses.
mora:
You might need to adjust your controller parameter
I was aware I could do that, but haven't. Do you think it is necessary? I remember back when I was building the controller I didn’t have the adapter to hook the controller to my pc. Did you get some usb adapter or something?
Also it is kind of a hassle to take my controller out and disassemble it enough to hook to my pc since I glued plexy glass to the sides. I can still take it out, but only if you really think it is necessary.
I’ll probably try all the other suggestions first.
Thanks to all for helping me resolve this
