Old 10-31-2009, 11:27 AM
Woodsmith's Avatar
Default Re: Using a forklift motor, and choosing a good one
Originally Posted by electromet View Post
Wood,
I noted that you expressed an interest in a 13" motor the other day, and I just want to make sure that you've checked all the appropriate clearances to the transaxle case & driveshafts from the cenerline of the motor shaft. It would be a shame to find out the darn thing doesn't fit alongside the MR2 mechanicals. Maybe you should make a cardboard motor mock-up?
Yebbut, if I could use a really big motor I probably would, but it would also be a waste of motor and weight!
The biggest I can get in is an 11" motor but I do have to be careful as it has to be 11" and not 11 and a bit. I only have a measured 1/8" clearance to the flange on the CV joint.
If I find it gets a touch too close I will machine a little off the CV flange, there is about 3/8" of flange that doesn't do much.
Old 10-31-2009, 01:20 PM
electromet's Avatar
electromet electromet is offline
electromet is on a distinguished road
I just wanted to make sure you did your homework. It looks like you're right on top of things.
Old 10-31-2009, 02:30 PM
gottdi's Avatar
gottdi gottdi is offline
gottdi is on a distinguished road
The commutator in this photo looks like doo! doo!
My EV has been built from off the shelf parts, no need to wait any more.
http://greenev.zapto.org/electricvw
Old 11-08-2009, 01:18 AM
scarab scarab is offline
scarab is on a distinguished road
the availability of second hand motors in western australia is zero.
what is the difference between say a 25 Kw generator and an AC motor of a similar size?
There are numerous second hand petrol/gasoline/ diesel generators up for auction from old mine sites etc.
Old 11-27-2009, 04:14 AM
Tesseract's Avatar
Tesseract is on a distinguished road
J...Seriously though, is my thinking correct in looking for an 11" over, say, an 8" or 9" motor for high speed cruising?
Nah... Plenty of people blast down the highway just fine with 9" WarPs, ADCs, Kostovs, etc... An 11" motor is going to have an awfully low top RPM limit without getting the commutator reinforced with Kevlar banding, etc... 8" and 9" motors are usually a better fit for most vehicles. That's just my personal observation/opinion, not really based on any extensive engineering analysis; worth price paid.
Jeffrey Jenkins
http://www.evnetics.com/
Old 11-27-2009, 04:44 AM
Hi, my donor vehicle i estimate a kerb weight of 1000kg with driver and fully converted, i am thinking of using a Kostov 11" 192V as its only $500 more expensive than the 9" 144v. would it be best to stick with the 9" as its half the weight of the 11" (41kg comparerd with 81kg)
thanks
Old 11-27-2009, 09:53 AM
paker paker is offline
paker is on a distinguished road
With the large amount of torque the 11" motor puts out would one need high RPM? The 11" 250v Kostov is supposed to top out at 5600 RPM.
Old 11-27-2009, 10:18 AM
jackbauer's Avatar
Well my 11.5" forklift motor pulled the bmw up a hell of a hill in 4th with two 5 year old batteries and a boot full of tools! Torque it has
Old 11-27-2009, 12:35 PM
What kind of amp draw do you have when you do that?
Old 11-27-2009, 12:45 PM
jackbauer's Avatar
Peaked at 400 motor amps.
