Old 08-18-2012, 11:55 AM
Rob_of_Waterloo Rob_of_Waterloo is offline
Rob_of_Waterloo is on a distinguished road
Default Vacuum pump polarity
Hi all
I have a MES Vacuum pump 70/6E from Metric Mind. I was just wondering if anyone knows the polarity on the two pin connector. I will contact the supplier on Monday, but i was hoping to install it today or tomorrow.
Old 08-18-2012, 04:49 PM
TEV TEV is offline
TEV is on a distinguished road
Default Re: Vacuum pump polarity
You suppose to have a mating connector. What color are the wires out of connector ?
Old 08-18-2012, 07:05 PM
Mating connector does not have any wires.....yet
Old 08-18-2012, 09:17 PM
TEV TEV is offline
Sorry, I was thinking to use the colors for finding polarity. No information on the web about the wiring. All I find was an internal diagram, if the pump has any part of the body made of metal you can try measuring between the metal part and plug pins, the negative pin may be connected to the body.
Old 08-21-2012, 06:19 AM
Vortex Vortex is offline
Vortex is on a distinguished road
Wink Re: Vacuum pump polarity
You can't go wrong. One way the pump runs constantly. Reverse the polarity and the pumps shuts off from the inbuilt pressure sensor.
Old 08-24-2012, 08:55 PM
TEV TEV is offline
Did you find out the correct polarity ?
Old 08-24-2012, 09:10 PM
The pump has two modes. Shut off once vacuum pressure is reached and continuous running mode. The polarity of the input wires controls the operating mode. You can't do any harm by reversing the polarity. Try one polarity with the suction inlet blocked, you'll soon know.
Old 08-27-2012, 12:20 PM
Thanks everyone. I have confirmed the polarity. Vortex is correct. The continuous mode is enable with reverse polarity to measure noise, vibration and quality testing. Internally there is a bridge rectifier.
