Originally Posted by Tedktis
That sounds like a great solution What volt/amp circuit breaker do you recommend for a 144V Wap9 with 1k Zilla? Can I just use a Siemens from Home Depot or do I need to special order it. We are installing a 240 V 15 amp breaker and receptacle to power my air compressor on my circuit breaker box, so I figured maybe they have one that could handle the amps for my EV for a maintenance or emergency disconnect.?
you CANNOT just use a 240v circuit breaker from home depot... those are for AC, and unlikely to function if the need arose to open the circuit while under load. DC power is much harder to interrupt, and the circuit breakers are quite different with stronger springs, larger gaps and magnetic blowouts to stop arcing.
read thru the sticky thread
http://www.diyelectriccar.com/forums...off-25318.html
consider buying a big fat GE, or using a gang of the AirPax available from one of our dependable EV retailers like kta-ev.com or EVolveElectrics.com
all builds should include a big fat Feraz fuse mid-pack, a circuit breaker with manual pull added, and fuses for everything on the 12v side as well as an inertia switch (mounted vertically) interrupt on your 'key on' 12v power to controller.
