07-13-2012, 03:28 PM
Re: Warp Factor III is now Alive!
If the resistance is 0.1 you are in trouble. The average resistance would be half that meaning 0.05 so the losses in a single connector block will be 3000^2 * 0.05 = 450000 watts of waste heat in every connector block. (Note: It is impossible to have this much resistance and still get to 3000 amps. If the resistance was actually 0.1 ohms per cell then you would be limited to a short circuit current of only 37 amps average) The resistance better be closer to 0.0001 which would give 900 watts of waste heat per side or 1800 watts per cell. Still too much as this is more than a space heater on every cell.
You need to run current from one side of your connector block to the other and measure the voltage drop from a point different than the connection. Divide the voltage drop by the current to get the resistance. Example. You pass 50 amps through the block and read a voltage of 0.005 then the resistance will be 0.0001 ohms. You may have to pass quite a lot of current if your meter doesnt have a millivolt range. The effective resistance will be about half of this because of the way the cells are paralleled.
Doug Ingraham
Rapid City, SD
07-13-2012, 07:30 PM
Ronald Adamowicz
President of The NEMRS
www.NEMRS.net
Enzo Ferrari "Horsepower sells cars, torque wins races".
07-13-2012, 07:39 PM
Finishing touches before hitting the track on the July 21st.
* EMUS BMS installed working properly.
* All tin complete and sealed.
* Water pump connected.
* Line-Lock connected.
* OD unit installed and wired.
* Seating brushes everyday.
* Installing rear window tomorrow.
* Gauges coming soon!
* Paint coming soon!
I see no problem racing on July 21st.
Ronald Adamowicz
www.NEMRS.net
07-13-2012, 07:47 PM
Originally Posted by Semper Vivus
Don't trust the last digit of a digital multimeter, even if it is a Fluke  .
With this setup, your measurement includes the contact resistances between the busbars and the probes.
Draw a constant current of for example 10A through it and measure the voltagedrop. This will give you a much more accurate result!
Kind regards
Tom
Okay, I took a charge pack of 3.77V discharged at 10amps and the pack dropped to 3.62V ???
Ronald Adamowicz
www.NEMRS.net
07-13-2012, 07:54 PM
I test just one single 3.88v lipo cell and discharged at 10amps on a icharge, the 3.88v dropped to 3.66v ???
Ronald Adamowicz
www.NEMRS.net
07-14-2012, 06:31 AM
... and the tiny 20awg wire connecting the probes to the meter. If the resistance really was 0.1 ohms, you'd have a 200 volt drop across that connection at 2000 amps.
Looking forward to seeing it run.
Why are the battery hold downs so loose, is there something that still needs to be installed?
07-14-2012, 07:02 AM
Think it's just the meter, I test a solid piece of copper bar, then a solid piece of aluminum bar and received the same resistance number, I am not worried.
Yes, tube are being installed today. The packs are also glued together, so consider then one solid pack.
Ronald Adamowicz
www.NEMRS.net
07-14-2012, 06:54 PM
Ronald Adamowicz
www.NEMRS.net
07-15-2012, 11:46 AM
Looking GREAT!!!!! Can't wait to hear what does this beast does on track.......
Albano dos Santos
07-15-2012, 01:30 PM
One word, WOW!!!!
Good luck, l;ooks awesome!!
